Question about Poulan Pro 22" Self Propelled High Wheel Mower
Lawn mower starts then stalls out and won't restart. Blades won't turn when the engine starts.
    Master:
  • 426 Answers
It's not getting enough fuel to the carb. It may have some water in the fuel so unless you are 100%certain it is good gas then I recommend draing all the gas out of the tank and also removing the carb and clean it.
Posted on May 18, 2014
  • Richard proctor
    Richard proctor May 18, 2014
    Would that affect the blades turning... It starts for maybe 10 seconds and then it doesn't start after that.
  • Steven's Electronics
    Steven's Electronics May 18, 2014
    The blades on a push mower are connected directly with the engine so yes it can, especially if the mower barely stays running.
3 Suggested Answers
  • 5 Answers
SOURCE: Continuously stalling and extreme difficulty restarting.
The brass "Bolt" that holds the "cup" on the bottom of your carburetor is also the main fuel metering jet for the engine. Get yourself a can of automotive carb cleaner, the aerosol type that comes with the small red plastic tube on the side of the can. Remove the "Bolt" and "cup". (Tip: tilt the carb side of the mower UP about 45 degrees and support it with whatever you have, wood, bricks etc. This will help stem the flow of gas from the tank while you have the "cup" removed.) Examine the "Bolt" and you will see one or two small holes in the side of the "Bolt" between the hex head and the threads. These are the metering orifices. Use the carb cleaner to throughly clean the "Bolt" orifices. (Tip: DO NOT attempt to 'drill' the orifices clean) Next, use the red plastic tube to spray carb cleaner up through the hole on the carburetor that the "Bolt" screws into. Be liberal with the cleaner. Finally, clean the "cup" with the spray one more time for good measure. Put everything back together. (Tip: easy does it on tightining the "Bolt") Level the mower, check for leaks and verify the oil level is OK. If the plug and air filter are up to snuff you should be good to go. (Tip: how old is your fuel? You should keep it around for only about 30 days unless you use fuel stabilizer. These little engines LOVE fresh fuel) Good Luck.
Posted on Jun 27, 2009
jlgprop
  • 352 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
FOR SURE CHECK ALL PREVIOUSLY MENTIONED ITEMS , TRY THIS...ALMOST GUARANTEE IT WILL RUN............ REMOVE "ALL" OLD FUEL, REFILL WITH FRESH HIGHEST OCTANE FUEL. REPLACE SPARK PLUG (YES, EVEN IF IT LOOKS OK!) GAIN ACCESS TO CARB OPENING, REMOVE AIR FILTER..OR WHATEVER. USING SPRAY CARB CLEANER, FILL ENTIRE CARB AND FLOATBOWL WITH CLEANER....WAIT OVERNIGHT IF POSSIBLE..IT WILL EVAPORATE. NEXT DAY SHOOT MORE INTO CARB..GETTING ANY JETS, ORIFICES ETC..FILL FLOAT BOWL AGAIN. P.S. CLEAN OR REPLACE AIR FILTER IF NEEDED! WAIT A WHILE, GAP NEW SPARK PLUG, INTRODUCE APPROX. 1-2 OZ. OF FRESH GAS INTO PLUG HOLE...QUICKLY RE-INSTALL SPARK PLUG ..WITH ON/OFF SWITCH-BAR OFF..PULL OR CRANK ENGINE A FEW TIMES. MAKE SURE IGNITION CAN FIRE, CRANK(ELECT. START) OR PULL STARTER ROPE & MOWER SHOULD FIRE OVER. IF IT STARTS..RUNS..THEN STALLS (AFTER USING UP GAS IN CARB, TRY IT AGAIN. IF IT CONTINUES TO STALL QUICKLY...YOU WILL NEED AT LEAST A CARBURATOR REBUILD, OR IF NO START AT ALL..YOU NEED TO SEE IF PLUG IS FIRING.
Posted on Apr 05, 2014
When I push up lever to engage the lawn mower blades it will not engage them and will stall the engine
If the operator seat saftey switch is defective the engine will stall.
safety-seat-micro-switch-fits-husqvarna-lr100-lt100-lt130-ayp-craftsman-rally-jonsered-mowers-532121305-121305-450-p-soavr15tiwcrglcekobpw2on-2-5.jpg Hope this helps?
Jun 23, 2017 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Reverse operating system
Check the switch down by the gear shift lever, and the wiring to the switch, if one of the wires has come off the switch it will give problems.
May 30, 2013 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
I have white zero turn 54" lawn mower. The engine runs but the blades won't turn on. Please any advise will help
This is a belt adjustment problem. You machines belt has either broken, or is loose to the point where it won't engage the blades at all, or has just slipped off the pulley. I believe the belts are on top of the deck covered by removable covers that are bolted to the deck. Check and see. GOOD LUCK.
Jun 17, 2011 | Hawk 36" Red Hydro Walk Behind Lawn Mower...
I ran over a gardening spade with battert powered craftsman mower. It will not start now. How do you repair?
have a look at the cutter blades if there all bent up they will be stalling the motor,,,best to fit new blades
but you may have "bent" the crank shaft in the engine as well,,,,get a compreshion test done on the engine to find out
Jun 27, 2010 | Craftsman 19 in Premium Battery Powered...
Everything works normal but when i let brake off engine stalls oh this is on a stx38 lawn tractor
If the mower is stalling when you engage the blades, then you may have something jammed in the underside of the deck. You could use a mirror to look under the deck and see what is jammed and not allowing the blades to spin freely.
May 03, 2010 | Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
100 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
