Question about John Deere Garden
445 john deere-temp gauge flutuates between hot and normal
Model 445
    Scholar:
  • 159 Answers
Try replacing thermostat.might have trash in it causing it to stick on occassion.
Posted on May 18, 2014
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
Daniel S
  • 4323 Answers
SOURCE: John Deere Model 445 garden
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 05, 2010
1010 John Deere tractor shuts down after temp gauge goes half way to hot
Sounds like the temperature gauge or temperature sensor is faulty and giving a wrong reading. Too high of an engine temperature will shut that engine down. Check the temperature with a temp gun if you can get one to see how hot it is before it shuts down. Aim it at the coolant line or the engine block. Or take the temperature sensor out and check it by putting it in a pot full of hot water with a temperature gauge and boil the water to see how high the temperature gets before the sensor closes or opens. Use an ohm meter across the sensor terminals to know when it's either opened or closed. Some of these are set up to operate in either open or close mode.
Oct 20, 2017 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
Where do i locate oil pressure sender on a john deere 445
Not sure but if you follow the sure from the oil gauge it should lead to it also match the color coding..good luck..
Feb 28, 2015 | John Deere Garden
I have a 2000 John Deere 990. The fuel gauge and temp gauge only work part time but always together.Any ideas?
I have owned a 990 since new. 2001. The fuel gauge started to act similar to what you described for a few years. Recently the temp gauge was also doing the same thing. I finally decided to chase the problem. Bought a PDF file of John Deere manual. The fuel and temp gauges share a common ground. I tool the hood and panels off that allow getting behind the instrument panel. ps, you don't need to pull the steering wheel. NOTE, disconnect the battery before you dive into it. I disconnected and cleaned ALL of the plug connectors with spray contact cleaner. Put it back together. The fuel gauge comes to life instantly. The temp is slow, but that looked normal, and worked. Then today the temp stopped working mid way thru an hour of using the tractor. After a palm slap to the side of the instrument panel the temp gauge instantly came to life. So there is also a issue with the gauge itself. I am going to assume that the gauge needle is stuck. so maybe some cleaner and lube in the gauge itself will solve the second half of the problem.
Sep 12, 2012 | Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
How do I change the temp gauge on a john deere 6400
The temperature gauge is built into the instrument cluster and it needs to be changed as a unit.Try removing the wire from the temperature sensor and ground it to the frame of the tractor to verify that you do need the instrument cluster replaced,ground that wire will drive the gauge to hot if the gauge is good and nothing will change if it is defective.If grounding the wire made it work then you need a temperature sensor.Good luck and let me know how you make out!
Dec 28, 2009 | John Deere Tractor Side Screen...
I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
Mar 30, 2009 | John Deere 42 in. EZ Trak Bagger
Garden Logo
156 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
