Question about Dewalt Laser Plumb Bob
How do i recalibrate laser plumb - Dewalt Laser Plumb Bob
Plumbing for jacuzzi laser sand filter 160L
top outlet from pump to intake of filter or labeled pump out of filter labeled pool or return waste to drain or hose to waste if pool heater out of filter to in of heater then out of heater to pool return
Jun 01, 2017 | Jacuzzi Pool & Spa
How do a get my tool to level it self? I have not used this tool in about 5 years it is like new. It has been sitting in my garage and I went to use it to set some plum and level lines and it will not
Bill the level is a pendulum type of device, therefore it is self leveling as long as it is within about 5 degrees of level. The pendulum has a lock for when it is not in use, make sure that you unlock this so the the unit can self level. It also has a flashing out-of-level indicator to warn you if you have not set the unit up within the 5 degrees of actual/real level. Paul.
Jan 03, 2015 | Robotoolz 5Beam Laser Level Plumb Square...
Cannot read disc
Xbox 360 or PS 3? Dirty laser lens on both, the 360 loses it's laser strength and may need to be recalibrated.
Nov 14, 2014 | Video Game Consoles & Games
Pacific Laser Systems PLS5. Are the left and right beams supposed to be at right angles to the down beam? I took another laser chalk line focused the PLS down dot on the chalk line beam. The left and...
one of the problems with this type of equipment is the fact that the down beam has to be set to a true plumb position. If it is possible to swing the head without disturbing the mounting you can check for circling - motion of the down beam in a circular pattern - which indicates off plumb placement.
Dec 22, 2017 | Pacific Laser Systems PLS5 Automatic Laser...
We have a bunch of PLS180 units that are out of calibration. Is there any way to adjust these back to level. I have some concerns about opening up the unit after seeing the warning about laser radiation...
The manual describes the procedure for checking level and plumb for the PLS180 but if you have determined that your units are out of calibration you are right to be concerned about opening the unit yourself. Please contact PLS at 1-800-601-4500 to find an authorized service center for your lasers.
If you cannot locate your manuals to check level and/or plumb I an attaching a link to the PLS180 manual as the methods for confirming level and plumb are quite detailed and should be followed exactly as described.
http://plslaser.com/sites/default/files/PLS_180_Manual_2008_1.pdf
Have a great day.
Dec 30, 2010 | Pacific International Pacific Laser...
THE LASER WON'T LEVEL I THINK IT NEEDS TO BE RE-CALIBRATED
If the tripod is level or close to it and you cannot level the laser, it needs recalibrated
Dec 26, 2009 | Measuring Tools & Sensors
Will not read the discs
Open the wii and clean laser With Swab and alcohol. Push the laser reader the the other end ( away from spindle motor). This will recalibrate and clean. Special screwdriver is needed to open. Triwing screwdriver can be purchased on ebay. If that dont work replace laser and tray. Good Luck.
Nov 20, 2009 | Nintendo Wii Console
HALF PRINTING(HALF DARK AND THE rest no printing)
Check with the cartridges. If you are using recycled cartridges it has these kind of problems. Try aligning your printer from the software. If you have new cartridges than also you can try aligning and in troubleshoot option it could be 'recalibrating/recalibration' use this option. And the best would be use software assistance and try to uninstall and reinstall the printer.
Mar 12, 2009 | Epson laser Printer EPL-6200L Laser
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
May 31, 2007 | Datalogic Gryphon D200 (901661076)...
Dewalt Laser Plumb Bob Logo
Top Dewalt Measuring Tools & Sensors Experts
ka4iup
ka4iup
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
