Question about Ovens
What does code f5 on magic chef range means? - Ovens
  • ken8080 May 20, 2014
    After the oven was turned on and reached the set temperature (375F degree) about 10 to 15 min. It will turned off and come out a F5 code with beep sound. After I clear the F5 code, I try to set the temperature again and it will show F5 again and won't work anymore. I can turn it on again after several hours and it will repeat the same problem again.
  • 26 Answers
The "F5" error code means there is a discrepancy between the clock's hardware and the oven circuit.
Clock assembly may need replacing.
Posted on May 23, 2014
  • bigestalever May 23, 2014
espressonist
  • 1711 Answers
SOURCE: I have a magic chef range. I ran the self cleaning
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Nov 25, 2010
  • 1531 Answers
SOURCE: Magic Chef oven displays F3 everytime the bake or
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Posted on Feb 12, 2010
  • 116 Answers
SOURCE: Magic Chef Oven
An F1 usually suggest a defective touch pad (The keys get stuck sometimes because long use or "over pressing" or poking it with things like knives and such). If its a unit with seperate touch pad and clock (controller) changing the touch would be enough othewise the whole controller has to be replaced. You did not give a model number so not able to give an exact price. But it should be in the region of $120 - 230 depending on the model you have
Regards
Posted on Sep 05, 2008
heatman101
  • 43501 Answers
SOURCE: I pressed self clean on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Nov 28, 2010
  • 5097 Answers
SOURCE: I have a magic chef electric wall oven and it
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Posted on Sep 25, 2011
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
Sep 25, 2011 | Magic Chef Ovens
I have a Magic Chef Electric Range RS-1. I am getting a fault code of F1. What does this mean?
Hi
F1 indicates that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Magic Chef Ovens
Am getting an "F-1" reading with a "beep"
Error code F1 means failed thermistor/transistor in control.
To resolve this issue you'll just have to replace the Electronic Range Control (ERC).
Good luck.
Apr 11, 2011 | Magic Chef 9815 Electric Single Oven
I have a magic chef gas range top , a drop in , and the igniters are all clicking at once , started on their own. any help. ??? Larry
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 13, 2010 | Magic Chef Ovens
I pressed self clean on magic chef ceramic range oven and get a dr code.
heatman101
Nov 28, 2010 | Magic Chef Ovens
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
Nov 25, 2010 | Magic Chef Ovens
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
My magic chef oven flashes F-5 when we try to turn on the oven!
Hi
Thanks for using FixYa. Error code F5 means Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction.
Turn off the Oven for 2-3 hours, the oven will reset itself. However, if the error still persists then follow the procedure to troubleshoot the error code--
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F5 and listen for the beep.
  • If you get the F5 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F5 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 13, 2009 | Ovens
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
138 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
