Question about Haier hwr10xc6 Air Conditioner
How do I remove an Aspen Air Dynasty Model# A-112
Someone several years ago installed it in the interior of a living room and applied apoxy around the entire unit.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Are you sure it is not silicone sealant?
As far as that, take utility knife and cut around it, then you can get the unit out and work on getting the rest of it off the house.
If it is actually Epoxy, good god, You might need to replace anything on the house that is is connected to (if good epoxy) Head to your local hardware store for some Epoxy remover, but it often harms anything it touches, but it does work after soaking the heck out of it."
Attack Epoxy Resin Glue Remover Adhesive Dissolves Cleaner Liquid...
Posted on May 18, 2014
Ignition switch on dodge dynasty?
I had a similar problem years ago. As long as your dash lights come on, it's likely you can use an external pushbutton switch to run the starter. There are likely just 4 wires on the ignition switch. Power from the battery, and switched to:
accessories
main car stuff (dash lights, ignition, signals, etc)
starter.
splice in wires from battery and starter to new switch, and you're good to go. This worked for years on my old car.
Jun 01, 2015 | 1992 Dodge Dynasty
93 dodge dynasty steering issues
Hey Laurie. It may be that the right brake caliper is running tight and when it heats up it will bind, like applying the brakes to the right front only. Does it straighten out when you hit the brakes? If so, that is most likely the problem. Tommy
Sep 06, 2014 | 1993 Dodge Dynasty
2004 honda accord ex how to remove pasenger side front speaker
You must remove the door panel (apply gentle pressure around several points between panel and door, end removal of at least one screw in the inside door handle). Once the interior panel is removed, there are several screws holding the speaker in place. Remove these screws and the speaker (once disconnected from the wiring) will come out.
Jan 15, 2014 | Vehicle Parts & Accessories
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Model kn-coeg-3 i get the gas alarm to go off once in a while. it shows around 253 on the display. i live next to dump. could there be methane gas in the air? i don't smell anything.
Yes, it's possible. But, the odor of methane gas from a landfill is usually noticeable.
My concern is where the combo detector is placed. It should not be in a room that a gas appliance is in. As, just the normal turning on and turning off of a burner, will leave a little residual gas in the air. But, it should dissipate very quickly. But, it could cause a false alarm, if the detector is in the same room as the appliance. Plus, the detector should always be plugged into a wall outlet no more than 2' off the floor.
Unfortunately, these Kiddie Combo Detectors are not all they cracked up to be. I respond at least once a day, to someones question about them. Many have had to return them to Kidde for repair of replacement. That's not a good track record.
My best advice is service (clean) the unit at least every 6 months, because they become clogged with dust, lint and/or pet air. You can accomplish this with a can of compressed air with a straw nozzle (like you clean your computer with). Remove the battery, which will give you some access to the interior of the housing and blow it out with the canned compressed air. Pay particular attention to the small vents on the front of the detector. Once complete, reinstall the battery and you're good to go. Don't forget to change the battery annually.
Hope this helps. Please let me know.
Feb 16, 2011 | Kidde Nighthawk Combo Gas/co Detector
Need a serpentine belt diagram
CLICK on the following LINK. It has several Serpentine Belt Diagrams, one which will match your specific engine and options (AC/No AC, Power Steering,..etc.) that you will need.
Let me know if this helped...
http://www.2carpros.com/car_repair_information/year/1991/make/dodge/model/dynasty/1991_dodge_dynasty_drive_belt_routing_diagram.htm
Mar 14, 2010 | 1991 Dodge Dynasty
How to change a timing belt on a 1989 dodge dynasty 6cly 3.0L
My sincere apologies for the delayed response.
I have only been a free contributor to this site for the last 4-months.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, however I am answering it either way.
Click on the following direct Link. It has several Diagrams you will need for your Timing Belt replacement. Included are the Cover Bolt Locations, Tools Needed and Marks for your specific engine.
You may also want to Print out these Diagrams for future use.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1989/make/dodge/model/dynasty/1989_dodge_dynasty_timing_belt_diagram_marks.htm
May 06, 2009 | 1989 Dodge Dynasty
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Ecoquest Fresh Air Purifier Quit Working
My husband came home and checked out the unit. He discovered that the cord was bad, so he replaced it with one we had. It works fine. The cord plugs into the unit at one end and into the wall at the other end. There was no rewiring needed. Problem solved!
Aug 04, 2008 | Ecoquest Fresh Air Living Air Purifier
Haier hwr10xc6 Air Conditioner Logo
57 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
