Question about Estate Washing Machines
Washer won't agitate or drain water out - Estate Washing Machines
  • Estate Master
  • 5,323 Answers
I SUSPECT THE DOOR SWITCH BUT READ TE FOLLOWING
No wash agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
Posted on Apr 25, 2016
  • 1122 Answers
SOURCE: My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
Posted on May 29, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
localwonder
  • 6784 Answers
SOURCE: FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
Posted on May 23, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
