Question about Sylvania Heating & Cooling
Why is my built-in thermostat not working on my sylvania 2000w convection heater
2 Suggested Answers
SOURCE: How to install a wall dimplex thermostat to a
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Posted on Sep 21, 2010
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
Favorit 84470VI
Heater, 230V./2000W.-d.32mm.
The heating element, which is encased inside a tube, is used to heat the washing water. The heating element is not activated during the drying phase. Inserted into the delivery side of the washing pump and coupled with the duct which directs water to the upper spray arm.
Built-in safety devices: Two thermostats
First thermostat: auto-reset bi-metal thermostat calibrated to 98°C and connected in series to one branch of the heating element.
Second thermostat: manual-reset fuse calibrated to 206°C and connected in series to the second branch of the heating element. If this fuse intervenes, the heating element is disconnected definitively.
25966855-vhkvuwxe0dpywjiqbdtoypy4-4-0.jpg Dado
Nov 18, 2015 | AEG Dishwashers
My Dimplex Cadiz 2000w heater has stopped working
The heating element may be open - check that out.
Sep 02, 2017 | Heating & Cooling
I want to buy form Costco a Sylvania Convector 2000 watts with built-in thermostat. I already have a wall electronic programmable thermostat.can I install this convector anyway and not plug the built-in...
No, you will only be able to use the heater's Thermostat.The programmable wall thermostat you already have is either an 18 volt or 24 volt thermostat. It won't work with a portable electric heater.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
Mar 03, 2010 | Heating & Cooling
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Oct 06, 2009 | Creda C362E Electric Kitchen Range
Heating & Cooling Logo
44 people viewed this question
Top Sylvania Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Sylvania Heating and Cooling Expert? Answer questions, earn points and help others
