Fireplace troubleshooting our damper is not working properly on lady Kitchener fire place fire goes better with door open
    New Friend:
  • 7 Answers
It may not be your damper, is your house insulated and sealed up .sounds like it, when you open the door you are giving it more air for your draft, may need to add a make up airkit to the home, often these days we are sealing our homes up too tight and not allowing enough air for draft, that fire place needs to breath, call your power utility company and usually they will come out and do an energy assessment at no charge, if this is a smaller home this may be your problem : )
Posted on Jun 24, 2014
There is a lever on the side of fire place. does it need to be up or doen when you use fire place
If you are referring to the damper in a standard fireplace, it should be pushed up to open it.
Jan 23, 2017 | Work Safety
Pleasant Hearth WS-2417-B stove. Why doesn't air control work?
then call the installer back , there has to be a damper in the pipe going out ,
Oct 31, 2015 | Home
My gas fireplace shuts off after burning about five minutes - both main burner and pilot shut off.
Most fire place burners have an oxygen depletion sensor on them nowadays. If you can restart it after a while, a few minutes or so, and shuts off, it is probably the oxygen sensor. The owner lights fireplace and shuts the door, and the fire depletes the available oxygen and the fire will start producing copious amounts of CO which is a hazard. Most fireplaces have a fresh air supply available to provide combustion air but needs to be opened for the fireplace to work properly. Check the manufactures recommendation as to the proper installation of the fireplace furnace.
Hope this helps
Feb 05, 2015 | Heating & Cooling
I have a Cozymizer gas fire. Does it need an additional vent fitted to the room in which it is installed?
If you have the Cozymizer 1, coal basket gas burner, it's meant to be placed into an existing solid fuel burning fireplace. The damper of the fireplace must be open during operation. If this is the case with yours, no additional venting is required. If this is not the Cozymizer model you have, please provide the correct model number.
Hope this helped and thanks for choosing FixYa.
Sep 15, 2011 | Heating & Cooling
We have a Marco fireplace and the damper does not shut. I push the leaver inwards but nothing catches to keep it closed. We purchased this house and the fireplace was replaced with Gas Logs but still...
when the gas logs were installed the vent damper should have disabled. it sounds like this was done.it is unsafe to close the damper with gas piped into the fire place. sometimes a "u" block will be placed over the damper blade. if the gas has been removed and not piped into the firebox anymore it would be safe to remove this
Jan 27, 2011 | Leisure HOMEPRIDE Electric Fireplace...
I want to know what a lever in a fire place is
The lever at the top of the fireplace operates the "damper". The damper is a door that opens the fireplace to the outside via the chimney.
The damper must remain open whenever a fire is burning in the fireplace to allow smoke to escape out the chimney instead of filling the fireplace and eventually, the room. The damper should be opened prior to starting a fire, otherwise the handle will be too hot to handle. Once the fire has gone completely out, the damper should be closed to prevent heat from being drawn out of the room / home. You can easily check is your damper is open or closed by simply looking up the chimney. If dark, it is closed. If light(er) it is open. Do not operate the damper while looking up - as dirt, soot, rust, etc. can fall when doing so.
The damper also prevents pests from enter the room / home. It is not uncommon for birds, bats squirrels, etc. from creating a home / getting caught in side the chimney.
I hope this helps - good luck!
Nov 12, 2010 | Coleman Heating & Cooling
Gas fire place does not turn on with the remote but turns on only with the switch at the lower left corner. It seems to be a direct vent type gas fireplace. I wonder if the damper is not opening and the...
you have no damper, it was removed to put gas unit in. chcek batteries in remore and in RECEIVER, receiver is usually forgot about it is insdie the bottom door more than likely, the fan only comes on when unit is up to temp, it has a heat sensor on bottom of unit, check wires on a gas valve for remore receiver as well, usually go on top and bottom screws
Jan 29, 2010 | Desa International Wall/Window Air...
I have a napoleon wood fireplace, I just installed it in a fireplace. It seems like I can't get any heat out of it. I installed a cheminee liner up the cheminee. I think that the heatloss is going up the...
an open fireplace is not going to heat your house only 5 feet in front of the fire place. 75% of the heat goes out your chimney and burns the wood very fast. sorry to say but if you are looking for heat you installed the wrong unit!
Dec 14, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
