Question about Rainbow Vacuum Cleaner Power Switch D3, D4, SE; Replaces Part
How to get to the rainbow SE vacuum off/on switch.
Vacuum cleaner switch will not turn on until I tap on the side of canster.
  • Rainbow Expert
  • 324 Answers
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Posted on Oct 15, 2014
SOURCE: Rainbow Vacuum Cleaner starts slow smells hot
We ahve a canister Rainbow E series with powerhead. We took the Handle apart because it was clogged and now can't figure how to put back together. Any help would be great.
Posted on Feb 02, 2008
SOURCE: rainbow d4 model wet/dry/vacuum cleaner
Go here.
http://www.zianet.com/alkone/Manuals/Rb_d4/rb_d4.htm
Posted on Mar 23, 2008
RockyNR1
  • 324 Answers
SOURCE: Power Switch
This is not that hard:
1. - remove gasket (it is glued so you may end up damaging it)
2. - remove 4 screws holding baffle
3. - under it you will see 4 more screws holding cap
4. - Four more screws and you will remove cap cover
5. - cut the cable tie, make a note how wires are connected, use flat screw driver to press on the latches holding the switch in while pushing onto the switch OUT. Tension will not let the latches pop back in.
6. - reassemble in the reverse order.
NOTE:
Switch - if you have old style switch installed you will need to push something into each hole next to the wires to release them. There is a cooper lip in each hole that you have to bend a bit to release each wire. Installing new style switch (with 4 wires) - attach one power cord wire to one blue switch wire and another to another blue switch wire. Attach one motor and one power nozzle cord receptacle wire to one black and another pair to another black wire.
Gasket - use weatherstripping glue to glue motor gasket back (you can get some in almost any automotive store)
Need parts - visit our store HERE.
No diagrams - sorry. It is Rexair, Inc. intellectual property and we can not use them...
Good Luck
Posted on Mar 12, 2009
  • 430 Answers
SOURCE: motor won't start
Most times this will be caused by one of 3 items, the cord, the switch or the carbon brushes in the motor. Inspect the plug area on the cord for strain twist it gently and look to see if the cord appears a bit white where it meets the plug or if the cord appears crushed just before the plug.
Also inspect where the cord meets the body of the vac for the same signs of wear or any locations where it may have been caught in the power head , etc.
If you have test meter, check for resistance change at the plug while twisting and finally try the same twisting with the vac plugged in if necessary but keep your fingers back from the plug in case the cord blows... gently twist and pull slightly to see if the motor continues to run.
Most often when a switch fails it just dies and doesn't become intermitant... so with a meter it will generally test good or bad , nothing else..
Sometimes on a well worn vac when the motor doesn't start the carbon brushes in the motor have worn down. A heavy duty motor such as the Rexair can often be rebuilt if brushes are required.
If you turn the machine on and bump or jolt the side of the body as if to spin it, you can often "trick " the motor into starting. If this happens it is most likely a carbon brush issue , if not time for a new motor.
Rainbow/Rexair machines have a fairly good motor however because of how they run drawing moist air through they often rust as they age. This is a tedius rebuild and best left to a pro shop with parts on hand if requiring brushes. Most shops will simpley scrap a worn motor if rusty and replace it completely.
Before you spend big $ on a repair or replacement....
One last thing....... pull the exhaust cap at the back of the vac. You will seen fine powder dust and residue.Wipe your finger across it. This is what the Rexair releases into your home each time it runs, but you don't smell it because it comes out in the form of humidity...like after a spring rain.
That same humidity is rusting your motor gradually year by year. Although this motor has a long life span, consider that you have been breathing dirty humidity as it runs. If you put orange drink crystals in the water bucket and run the vac, the exhaust air would smell like orange juice,... so what is in the tank comes out in the air, including your dirty water.
Most Rexair owners buy thinking they are helping to reduce allergins.. yet what is on that exhaust plug proves otherwise. If your home is essentially carpet free and you are vigilant maintaining and rinsing the bucket, you might consider rebuilding this vac.. Otherwise consider a good High end European vac like a SEBO,MIELE, Nilfisk etc for better filtration and reliability
Posted on Oct 10, 2009
  • 114 Answers
SOURCE: Rainbow SE vacuum cleaner has no power
Invert the vacuum cleaner without the water tray installed. With the machine unplugged, give the separator a spin clockwise. If it spins easily, this is a good sign. If the bearings are good on an SE, you should hear the faintest of rapid clicking sounds as you spin the motor. This is the sound of the brushes as the commutator segments pass under them. The brushes on SEs will sometimes hang up and not make proper contact; they are too precise a fit in their holders and the carbon dust they generate plus a tiny bit of moisture will cause them not to extend as they wear. When this happens, the brush tension spring overheats, relaxes, and it's time for new brushes and a service. Anyway, if you determine that the motor is turning smoothly (resistance or binding indicates bad bearings), install the water tray dry, plug the vac in, switch on, and give it a couple of bi__ch slaps with the palm of your hand on the side of the vac near the top. This can sometimes free up a stuck brush but the effect is likely not to last. It will, however, give indication of whether the machine might run or not after a fairly cheap repair (under 100 dollars).
Posted on Dec 22, 2009
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Rainbow vacuum cleaner won't turn on.
The 4 main problems we see is #1 The Plug needs replaced due to lack of continuity and #2, the 2 pole 2 throw on off switch has failed on the 120 V motor side of the switch.
One side of the switch is for the main motor and the other is for the power to the power head socket on the vacuum it self.
The 3rd is the motor brushes are seized due to a dirty motor or 4, the motor's armature is blown
Check the continuity of the 120 V cord first, then proceed onward.
I hope this helped!
William R
Feb 01, 2015 | Rainbow Vacuums
Apr 04, 2009 | Rainbow 75th Anniversary Canister Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Apr 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE (1991)
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Mar 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE Power Switch
The 2 clear side panels come off, remove the screws there, then the top will come off and you can get to the switch from there also.
Jan 30, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum Cleaner Power Switch D3, D4, SE; Replaces Part Logo
357 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
