Question about Ovens
Sa310x5 smeg oven not heating up, one green light on the right.. Please help
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
  • 146 Answers
SOURCE: smeg single fan oven
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
Posted on Dec 24, 2007
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
  • 86 Answers
SOURCE: NEED USER MANUAL FOR SMEG SE375MFX5
SMEG SE-375MFX5 Owner Manual
Posted on Feb 09, 2009
Smeg SE250XUK only oven light works, no fan no heat please help
door switch defective,,try to open close again & again
Feb 12, 2015 | Smeg Ovens
Oven not heating up
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Apr 05, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Oven not working but grill is please help
Dec 12, 2010 | Smeg SE250XUK Stainless Steel Electric...
Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
Sep 10, 2009 | Smeg Ovens
The light and fan works but no heat comes on in oven.
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg oven ss336-5 not heating
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
