Question about Ovens
Sa310x5 oven not heating up. Only one green light on. I don't have a manual, please help
My oven don't light up a lot
it's an electric or gas oven? what's the brand and model name?
If it's an electric oven, perhaps the heating elements are not connected in the back of the oven. Please try to pull the connector between the serpentine and the back wall when the oven is cold.
Sep 18, 2013 | Ovens
Help it lights up but no heat.
Dont use it! You need to pull the cooktop and see what is wrong. There is a chance that the circuit for the surface light is the only standing circuit left because the heating element is bad or loose
May 20, 2013 | Ovens
Oven wont heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 06, 2011 | Zanussi Ovens
Brand new oven, maytag, the oven won't heat up and
IF IT IS STILL UNDER WARRENTY DON"T TOUCH IT CALL THEM BACK , MAYTAG HAS MANY PROBLEMS BUT THEY ARE GOOD AT REPLACING UNITSTHATHAVE PROBLEMS , PLEASE LET ME KNOE WHAT HAPPENS IF YOU NEED ME TO CALL THEM GIVE ME THE INFO AND I WILL DO THIS BUT SHOULD BE OK
Dec 01, 2011 | Maytag Ovens
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 | Ovens
Fan not heating
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
The light and fan works but no heat comes on in oven.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
