Question about Mongoose Cycling
How do i take apart the brake casings and replace them?
The brake cables will not move through the casings as far as i can tell. i tried lubricating the cables to no avail. how do i take apart the casings and replace them?
  • 24 Answers
Usually the nut on the rear brake caliper is a 10mm. Loosen the nut and the caliper should spring open. Pull on the cable housing where it touches the caliper and it should pull out of the cable clamp that you loosened to start the process. Pull the cable housing off of the cable. Look at the cable and see if it is rusty. If it is then replace it. There is a good chance that the cable housing is rusty inside of it as well, it's a good idea to replace it too. Go to your favorite bike supply store and get a replacement cable and housing that is longer than the one you removed. When you get back to working on the bike , remove the cable from the housing, if it has an end on both ends of the cable cut the one off that you don't need. Once you have the cable removed from the housing pick up the cable housing, compare it to the original housing and cut the new one the same length as the original. Thread it back into the holders on the bike as the old one was. Now install the cable onto the bicycle. Let the new cable protrude out of the housing, thread it into the cable clamp that you loosened in the beginning, squeeze the caliper together and pull on the cable. Now that you are holding the cable tight with one hand take the 10mm wrench and tighten the clamp. Project finished.
Posted on Jun 25, 2014
I have a 99 Kawasaki Vulcan 800 the throttle is beyond hard to twist and give gas I lubricated the the cab?Ex after taking g it apart at grips but no prevail can anyone help me with this problem?
When you disconnect the throttle cable from the hand grip control can you move it freely? If not then the cable is either broken inside or something has jammed it inside the sleeve preventing it from moving. If so I would replace the throttle cable.
If the cable moves fine when not connected to the grip then you installed it wrong somehow. Take it all apart and reinstall.
Apr 14, 2017 | kawasaki Motorcycles
Honda hrax217vka will not stop running
You may have to take the engine shroud off- but maybe not. Follow the the brake cable as far as you can. Take a garden hose and clean out where the cable is located on the engine. Then take WD40 or the like and spray in there to lubricate the mechanism.
May 25, 2014 | Garden
Fix emergency brake stuck
On 88-93 models the brake goes to the rear calipers. First you should release the brake and look at the little arms the cable attaches on each caliper. If the cable is moving but the arms are not, you need to replace the caliper(s). More likely you will see the cable is not moving, in which case the cable(s) need to be replaced. Swapping in parts, or trying to free up and lubricate existing parts will depend upon your skill set, time, and budget.
Apr 01, 2014 | 1990 Saab 900 Hatchback
88 pathfinder wont engage
check your rear brakes brakes could be locked due to frozen park brake cable or cables
Mar 07, 2012 | 1988 Nissan Pathfinder
The front brake wont release to install the tire. please help!!!
Remove the front wheel at the axel and move it around so that the front brake pads can be pushed closer together. Once you push the brake pads, the cable should have enough slack to allow one end to come out of the holder. Now the brake pads should be able to spread far apart so you can remove the wheel/tire assembly.
Gary
Jan 09, 2011 | Sport & Outdoor - Others
Dura ace brifters very sticky
You can squirt them with a spray lubricant (bicycle lubricant) to free them up if it is just a dirt issue, you need to pull the brake lever to expose the internal gearing mechanism, don't take anything apart.
If your shifter part is sticky, this usually clears things up. If it does not make trace through the derailleur cable and make sure it's not the cable hanging up instead of your shifter. Replace the cable and housing as necessary.
If its the brake lever, smae check of the cable system but also check the brake itself. The lever will feel sticky when there is a snag in the cable or if the brake is no longer returning with the same spring tension.
After that you can have them rebuilt or replaced. Depends on which model you have 8, 9, 10 (7800, 7900) as too the exact recommendation.
Dec 30, 2010 | Shimano Cycling
I have a Mongoose Blackcomb. When I apply the front disc brake the cable and actuator arm do not retract back to open position. Does the entire front brake need replacing are can this be repaired?
Impossible to tell you with out seeing the brake.
However, the brake can be repaired. I would suggest taking into your local bike shop so they can assess what is causing the sticking brake, it could be a very simple fix, such as adjusting the spring tension, to a more complicated fix that involves replacing broken parts. Some brake systems do not have available replacement parts and in those cases you would have to replace, but that is less common.
If you can, take off your front wheel and prop the bike up so you can see the brake working while you squeeze the lever, see if the pads move in and out. that is the first step to diagnosis. If they don't return, then look for a round adjustment knob on the side of the brake and see if that moves the pads in or out, if that knob does nothing that is most likely your problem.
Dec 30, 2010 | Mongoose Cycling
Right rear brake appears to be locked
Your rear brakes are not releasing. Make sure your brakes are fully released. Pull up and down on it a couple of times.Jack up the rear of the vehicle to get the tires of the surface and see if you can turn the wheels by hand. Brake cable may be bad. do this and post again
Dec 11, 2009 | 1992 Honda Civic
2005 parking brake stuck
The parking brake cable should be replaced but in the short term try getting under the truck and grabbing the cable casing and move them around to get the seized cable inside the cable casing to release keep working the cable until it releases if this doesn't work replace both cables.
Sep 11, 2009 | 2005 Chevrolet Colorado
Cycling Logo
55 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
