Question about Keys Fitness KF-T2.0 - Treadmill
New treadmill was fine the first time it was used Elite t2.0.
The second day it keeps showing E03. checked connection. What else can I check? Thanks
    Master:
  • 426 Answers
There is a speed sensor on the drive motor, make sure it is still in place
Posted on May 18, 2014
Tread mill display start and work stop and E03
You have to check whether the Motor runs before its shows the Error E#. If so you have to check the speed sensor. Can be it displaced or faulty. You will find the speed sensor near the motor pulley.
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 22, 2016 | Exercise & Fitness
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
I bought a elite saracen treadmill n it says error code 4 what does that mean please n e wun help me pliz
reset the treadmills, follow this steps and fix it. GOD BLESS YOU
However you must RUN the software calibration for fix it. see your owner manual. or download free from www. fitness.manualsonline.com
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
GOD BLESS YOU
Nov 08, 2013 | Exercise & Fitness
Pacemaster gold elite giving error code 133. Checked all connections so far and continuity through wire connecting top and bottom boards. No luck
please reset the treadmill, follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Oct 22, 2013 | Exercise & Fitness
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Mar 23, 2009 | Nordic Track NordicTrack A2350 Pro...
DVL315 Did get hot NOW Error E03 Showing up
Take the battery out and leave it somewhere cool (not cold - over 10 degrees C) for 24 hours - this may help.
Jun 13, 2017 | JVC GR-DVL315 Mini DV Digital Camcorder
Keys Fitness KF-T2.0 - Treadmill Logo
75 people viewed this question
Top Keys Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
