Question about Keys Fitness KF-T2.0 - Treadmill
New treadmill keeps on showing E03. Was fine the first time I used it but second just would not go. Any advise.
  • Steven Brandon
    Steven Brandon Jan 14, 2015
    First Sorry for the late reply, I have been sick. Second I am going to send u a link for a manual. Scroll throught the manual til you get to calibration. Follw the instructions for calibration then get back with me and we can go further.http://www.fit-fix.com/keysfitness/Servi...
    Master:
  • 460 Answers
It is a misaligned or faulty speed sensor located on the main motor
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on May 18, 2014
  • Nicola
    Nicola Jan 12, 2015
    Hi Steven. I have just read your comment as i have the same problem. York suggested a new speed sensor which ive got but it still doesnt work. any suggestions??
  • Steven Brandon
    Steven Brandon Jan 12, 2015
    If the speed sensor is not aligned correctly then it won't work. Try adjusting the sensor so that you can stick a dime or a quarter between it and the flywheel.
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
New treadmill was fine the first time it was used Elite t2.0.
There is a speed sensor on the drive motor, make sure it is still in place
May 18, 2014 | Keys Fitness KF-T2.0 - Treadmill
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Can you advise please
reset the machine make this: God bless you
    • 3
    • 4
    • 2
Nov 28, 2013 | Precor 935 Premium Series Treadmill
I have a pro fitness folding treadmill. It shows 'er 3' in the time box. Is there an easy fix for this?
reset and restart. God bless you
Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Oct 04, 2013 | Exercise & Fitness
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
Lifespan fitness focus treadmill E03 error
repair the magnet wire, adjust the magnet and reset see the diagram attached.Clean it.
5_6_2012_11_28_07_am.gifsincerely. God bless you
Apr 21, 2012 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
DVL315 Did get hot NOW Error E03 Showing up
Take the battery out and leave it somewhere cool (not cold - over 10 degrees C) for 24 hours - this may help.
Jun 13, 2017 | JVC GR-DVL315 Mini DV Digital Camcorder
Keys Fitness KF-T2.0 - Treadmill Logo
493 people viewed this question
Top Keys Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
