Question about Weslo PURSUIT CT 4.2 Recumbent Cycle
How can I decrease pedal resistance even dial is to lowest level. Still to hard to rotate
    New Friend:
  • 11 Answers
That is what it is made for, or maybe problem with the rotation system
Posted on May 18, 2014
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
How to set temperature on a general electric
Copied from ehow.com
Instructions
    • 1 Open the fresh food compartment and locate the two temperature control dials. Each dial is labeled for the compartment that it controls.
    • 2 Rotate the dial to increase the temperature setting by one to lower the temperature of the compartment. Rotate the dial to decrease the temperature setting by one to raise the temperature of the compartment.
    • 3 Wait 12 hours to allow the temperature in the compartment to stabilize before increasing or decreasing the temperature further.
Read more : http://www.ehow.com/how_8772966_adjust-temperature-controls-ge-refrigerator.html
Aug 28, 2014 | Refrigerators
Temperature indicator
You may have a problem with the coolant temperature sending unit and or the fuel level sending unit or an issue with the instrument cluster.
Apr 17, 2014 | Hyundai Excel Cars & Trucks
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
How do I change the belt on my Kirby G 2000 Limited Edition?
Lift the head two pedal clicks off the carpet.
Lift the headlight and you will find a silver thumb dial to remove the carpet head. At the front of the head there is a square dial which you must rotate to release the belt if not broken. Rotate the square dial , then release the silver thumb dial under the light housing and the head will detach.
Flip it upside down to expose the brush and open the grate covering the brush. Note on either end there are colored leveling blocks for the brush. Reinstall with same colors showing.
Clean any hair and thread from the brush roll and insert new genuine belt. reinstall in opposite order, Be sure to turn the square dial backward to align the belt in a twist pattern before reinstalling the head onto the vac.Then lower onto carpet with pedal.
Sep 14, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
Tps?
You may have a bad connectors to the Throttle position sensor. A TPS is actually a varistor, or same thing as a variable resistor. It is like the volume control on old stereos that do not have digital volume control. The computer determine throttle angle by input current which varies with the resistance. Make sure the connectors are good before you change it otherwise a new one will not solve the problem. I know how to check a TPS, but it is hard to explain how to do it, but I will try anyways. The TPS has 3 terminals. The resistance should vary as you turn the TPS. In respect to the middle terminal one side will increase, and the other side will decrease in resistance value. Sometimes it is not the center terminal that is the common point. so either way out of three you one that is common to both which should vary in resistanced in oposite ways, one side decreases, and the other increases as it is turned. A short course in electronics. As elctricity flows trough a resistance its current decrease as the resistance increase. The resistance value on a TPS should be around a few thousand OHMS, and the lowest value is around 500 OHMS.
Aug 13, 2009 | 2003 Jeep Grand Cherokee
Sub Fuel Tank
Very Hard!!!! There are no specs on this, the only way out is to go to your nearest dealer and look at a sender unit and measure its resistance and compare the 2 sender units resistance. It should be measured in Kilo holms, the way to measure it is read the resistance when the floats at its 'lowest' point, and the resistance sould either increase or decrease when you move the float 'up', this depends on what resistance the fuelguage requires, to test if the fuel guage works,'take the positive cable that plugs into the sender unit, fuse it with a low ampeage fuse and connect it to body/chassis while key 'on' and check fuel guage, it must go to full position, there could be another problem, check cables for opencircuits, and check earth(-)connection to the sender unit, plse post to me for further assistance Mishdaman.....
May 25, 2008 | 1992 Toyota Land Cruiser
Weslo PURSUIT CT 4.2 Recumbent Cycle Logo
404 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
