Question about Toro Garden
Toro zx 5420 oil change
Can't get the vent plug out
  • 140 Answers
The lug is under the mower. There should be a square plug that is the oil drain plug. Disconnect the spark plug first then remove the oil drain plug. You should have the muffler facing up because oil will get into the cylinder and cause blue smoke when the engine starts if you don't.
Posted on Jun 03, 2014
Savage smokless powder muzzleloading rifle broken vent liner in breech plug is this a common problem also is there any upgrades for this are parts still available for this rifle any info would help
Check out these links and the bottom link
Precision Rifle Savage Vent Liners - Precision Rifle Home
https://www.prbullet.com/vl.htm
  1. Cached
  2. Similar
Savage 10 ML II Single Hole Vent Liners. The hole in the factory Savage vent liner measures .0305". By experimenting with a variety of breech plugs utilizing ...
Precision Rifle Home - the world's most innovative Muzzleloader Bullets
  1. Cached
  2. Similar
Precision Rifle - Manufacturer of the world's most accurate muzzleloader ... Savage Smokeless Muzzleloader - could it be the Ultimate? ... Savage Vent Liners
Cleaning frequency recommendation for a Savage muzzleloader
https://www.savagearms.com/firearms/cleaningmuzzleloader/
  1. Cached
  2. Similar
If you have fired either black powder or Pyrodex® through your rifle, use any good ... Thoroughly clean the breech plug and removable vent liner of fouling with ...
Vent Liner for Savage MLII and all Lehigh Breech Plugs - Lehigh Bullets
https://www.lehighbullets.com/.../vent-liner-for-savage-mlii-and-all-lehigh-breech-plu...
  1. Cached
  2. Similar
US$27.00 - ‎In stock Direct replacement vent liner for the Savage MLII muzzleloader and all Lehigh breech plugs. The domed head and computer modeled internal design improve ...
muzzleloading rifle broken vent liner in breech plug Google Search
Dec 19, 2016 | Optics
We are in a rental property and an SC10 slow cooker has been provided. (It works very well.) We both thought that the vent in the lid had a plug insert. After washing the lid, we noticed there was no...
Usually a pressure cooker has a vent to release too much pressure
and reading the features do not mention a plug in vent.
Recheck with the land lord better safe than sorrow .
Feb 23, 2015 | Hamilton Beach Crock Pots & Slow Cookers
My frigidaire gas dryer will not heat
Good Morning Margie,
I see that you are having trouble with your Frigidaire gas dryer heating. I also see that the vent is plugged. You definitely do not want that vent plugged. Your dryer needs proper ventilation in order for it to work correctly. The reason it might not be heating is due to the fact that that vent is plugged and is not getting enough ventilation. Unplug that vent, make sure that there is gas going to the appliance, and that the gas supply valve is open.
-Best Regards-
WP
Apr 01, 2014 | Frigidaire AGQ6000ES Gas Dryer
5 speed 4x4 geo tracker transmission vents
i know that 5sp well, rebuilt 2.
there just one vent. on top. of just IT. part 21
there are 2 rubber plugs on the rail detent , plungers, that fall out.
all seen here.
see plugs rubber, #13 , suz still sells them. glue them in,
http://www.fixkick.com/tranny/5speed-rebuild.html
Mar 01, 2013 | Geo Tracker Cars & Trucks
Takes approx three 60 minute cycles to dry a medium size load. Vent pipe and filter is clean.
The house exhaust vent is plugged and needs to be cleaned out. To test, remove vent from dryer and run a load. If dryer works normally, it is your house exhaust vent that is plugged.
Jun 16, 2011 | Dryers
No heat
Suprisingly enough, dryers that are not heating more often than not have a plugged outlet to the venting. Pull your dryer out, remove the vent tubing and make sure that it is not plugged. Also make sure that the opening in the dryer is not plugged leading to the venting.
Feb 10, 2011 | Kenmore 700 6972 Dryer
Need to cycle three times before clothes dry
morethan likely your vent is plugged with lint. the vent should be cleaned yearly to prevent fires and to provide maximum efficiency. move yoy dryer out and disconnect the vent from the dryer and inspect the hose for blockages. it can also be internally in the dryer along the channel the heat is vented through. clean out all the lint and try again. usually this fixes the problem. especially long vents or angles in the vent are more likely to plug up so remove those if possible after you clean it out. good luck. always unplug the unit while working on it.
May 28, 2010 | Frigidaire Dryers
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Splendide 2000 dryer venting
Absolutely. You need to pull the unit out. Not what you wanted to hear. It not a pretty job.
www.coachtech.info
Feb 15, 2009 | Splendide 2000S Vented Washer/Dryer
Garden Logo
63 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
