Question about Hotpoint Washing Machines
What was the Year Model #VBXR1090D was made? - Hotpoint Washing Machines
    Master:
  • 426 Answers
All may have that same model number but produced on different years. The date code is usually stamped near the model number.
Posted on May 18, 2014
We have a Hot Point washer, model #V1WSR4162G1WW. The agitaor won't spin. I looked on Hot Point web site for help, but it doesn't list our model number. Can you help?
Typically the model number on hotpoint is 4 letter first and then a combo of numbers and letters
is should start as VWSR------------
so when i searched without the 1 after the V i found your model and believe the coupler between the agitator and transmission is stripped that is fairly common and fairly easy to repair. This youtube video will show you exactly how to replace that coupler http://www.youtube.com/watch?v=N26MCQKuXn0 the part number for that coupler kit is WH49X10042 it could be purchased at your local appliance parts store,or on online at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
applianceparspros.com
I hope this will help you be able to repair your washer,
Gene
Aug 06, 2011 | Hotpoint VBXR1090D Top Load Washer
Dirty Laundry...
It has nothing to do with the filter and everything to do with a failed heater element. Even if you can get the element replaced, the machine is now seven years past it's original five year design life and you may simply find that another major failure occurs shortly after repair.
You may be able to get around the problem by switching to a cold water laundry powder. it costs more, but is far cheaper than a repair.
May 16, 2010 | Hotpoint VBXR1090D Top Load Washer
How to remove agitator
If this is a Hotpoint.You should just be able to pull it up and out. Sometimes they stick. Usually you can just reach in and put your fingers underneath on opposite sides and pull up and they will come out. If they are stuck bad you may need a special tool to get it out without breaking it but that is rare.
Mar 18, 2010 | Hotpoint VBXR1090D Top Load Washer
Fills up won't agitate
YOUR MODEL IS NOT A CORRECT MODEL THE POSSIBLE STARTING LETTER WILL BE; G, H, M, P, Q, S, R, W OR X. AND THEN THE 1090 IS ALSO INCORRECT. YOU COULD HAVE A PROBLEM THE THE AGITATOR SPLINES INSIDE THE AGITATOR THAT HAVE BECOME STRIPPED IF THIS IS THE CASE THE TRANSMISSION SHAFT THAT TURNS YOUR AGITATOR WILL NOT GRIP AND YOU WILL GET VERY LITTLE OR NO AGITATION. IT COULD ALSO BE THAT YOUR MOTOR IS GONE OR HAS A BAD START RELAY. NOT ALLOWING IT TO OPERATE.HOPE THIS HELPS.
THANKS
Oct 12, 2009 | Hotpoint VBXR1090D Top Load Washer
Just trying to remove the agitator and can't figure it out
remove the fab softener cup and look for bolt in center of agitator. There may be a cap over it just pull it out and you should see the bolt remove the bolt and your agitator should come out. to remove the softener cup rpy it up gently it pop on.
Apr 02, 2009 | Hotpoint VBXR1090D Top Load Washer
Water wont drain
can you manually set it to spin? if nothing happens when you do that then check your lid switch
Feb 18, 2008 | Hotpoint VBXR1090D Top Load Washer
Wet clothing
Does water run all the time or part of the time. Some water is injected during the spin cycle to remove excess soap and softener.
Dec 14, 2007 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
