Question about Alto-Shaam 1000 TH II Cook and Hold Oven Stacked Mobile Holds 16 Food Pans
I replaced two thermostats on the lower steamer and now the temp wont go over 250, any ideas 727-608-7654
    New Friend:
  • 11 Answers
Battery is dead, buddy
Posted on May 18, 2014
2002 Jetta 1.8T blew 40A cooling fan fuse - overheated, destroyed 4 way cooling hose connector - replaced all- now it still runs very hot, inside temp reads 190 (but temp is much higher), cooling fans run...
Then replace the thermostat, because if on lower hose not hot and on upper hose scalding hot = antifreeze flow blocked by the thermostat wich remains closed!!!
Thermostat replacing:
Aug 27, 2010 | 2002 Volkswagen Jetta TDI
2000 Chevy Silverado normal operating temp is 210 , recently temp rises to 250. Its been this way for a few days, common operating temp is around 240-250 now, but does not overheat. Coolant levels are...
250 TOO HOT FOR ENGINE AND TRANSMISSION. SOUND LIKE COOLING FAN CLUTCH BAD ITS FREEWHEELING NOT LOCKING UP TO DIRECT DRIVE TOO COOL ENGINE OFF BECAUSE THE FAN CLUTCH THERMOSTAT NOT WORKING THE HOT SILICONE OIL CAUSE IT TO EXPAND TO PUT RESISTANCE ON CLUTCH TO PUT DRAG ON FAN CLUTCH CAUSING IT TO LOCK IN GIVE IT DIRECT DRIVE.I WOULD STILL REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP IF TEMPERATURE STILL 250 DEGREES YOUR RADIATOR AND COOLANT SYSTEM NEED FLUSHING.
Aug 17, 2010 | 2000 Chevrolet Silverado
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Lower rad hose blew off. replaced thermostat. ran fine 2-3 days.then upper rad hose blew off. now temp gauge wont go over 120 degrees
Something is building up pressure. Cheapest thing first replace the thermostat then try the water pump then the rad.
Oct 15, 2009 | 1994 Jeep Grand Cherokee
1999 Aprilia RS250 won't come up to proper temp.
hi mate when you put the coolant do you bleed the system to get the air out of the cylinder
Aug 25, 2009 | 1998 Aprilia RS 250
The lower oven in my CMT 21 Thermatronic II oven will not heat properly. I set the temp. at 350 and it will only heat at 250 as an example.
if it is not turning red, the element needs replacing. if it is turning red, thermostat or control panel issue
Jul 22, 2009 | Ovens
Temperature drop on freezer
Sounds like the thermostat is erratic.
Apr 20, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
2004 Envoy XUV - Causing me to be a Human Thermostat. My heat cycles between cold and hot air. When I set the temp to say 73 degs, the air will blow warm for a bit (like it should), then it will start to...
your vechicle has several temperature sensors you have a lower left and right lower temperature sensors .they are in dash.this is a dealership job.
Apr 19, 2009 | 2004 GMC Envoy
Alto-Shaam 1000 TH II Cook and Hold Oven  Stacked Mobile Holds 16 Food Pans Logo
81 people viewed this question
Top Alto-Shaam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Alto-Shaam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
