Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
What are the head torque spec. for Kohler pro 17 hp ohv model # cv490s
Cylinder head spec. for Kohler pro 17 hp ohv engine
  • 246 Answers
SOURCE: missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 246 Answers
SOURCE: canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
mickey813
  • 472 Answers
SOURCE: 27 hp kohler v-twin ohv backfires, and @
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
Posted on Oct 08, 2009
  • 12650 Answers
SOURCE: 17 hp kohler that is dumping gas out the muffler
carb float sticking open dumping gas into cylinders
Posted on Oct 19, 2009
  • 1833 Answers
SOURCE: I have a Craftsmans riding
according to your problem first make sure the battery is OK and check the wires are connected properly. Check the engine. You can rotate the engine governor shaft clockwise and tighten the governor lever. You can contact your nearest technician.
Posted on Mar 17, 2011
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Torque setting cylinder head bolt
Try posting in the automotive area! You should get somebody there that can help.
Jun 25, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
We are replacing head gaskets on kohler command 25 68500,what are the torque specs for head and intake gaskets?
first torque to 16ft/lbs in a x patt. then 30ft/lbs in a x patt. for head the intake gaskets connecting to the head should be 12 to 17
Feb 02, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Engine torque specs for 1996 chevy cavalier 2.2l
For 1996 Chevrolet Cavalier 2.2L SFI OHV 4cyl the check the next Head Bolt Torque sequence...
------------ front | 8 4 1 5 9 | of | | engine | 7 3 2 6 10 | ------------
Step 1: torque long bolts 8,4,1,5, & 9 to 46 Ft/Lbs torque short bolts 7,3,2,6, & 10 to 43 Ft/Lbs
Step 2: torque all bolts an additional 90 degrees Recheck final torque in sequence
*** CAUTION *** engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Hope helps (remnember rated this).
Jul 15, 2010 | 1996 Chevrolet Cavalier
Torque specs for 1998 26hp kohler head bolts. aluminum head
I use 150 ft lbs on my racing 2-cycle engines, tighten in a star pattern.
Sep 16, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
Sep 08, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
23 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
