Question about Electrical Supplies
Wiring diagram for 1987 suzuki carry
Need to fix the wiring for lights and indicators from inside the steering wheel and need a diagram . so i can rewire them again
  • 45 Answers
SOURCE: steering wheel audio controls wires
those controls will only work with your factory audio unit not aftermarket ( it has an interphase )
Posted on Aug 28, 2008
  • 41 Answers
SOURCE: need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Posted on Dec 19, 2008
  • 290 Answers
SOURCE: need wiring diagram for radio on 96 mercury sable
http://www.the12volt.com/installbay/stereodetail/1500.html
Posted on Mar 23, 2009
  • 14 Answers
SOURCE: Ignition wiring circuit - 1987 Suzuki Samurai
http://www.acksfaq.com/faqsearchresults-.php
Posted on Apr 23, 2009
  • 6 Answers
SOURCE: I need a wiring diagram for 1987 Chevrolet 3/4 ton
The Haynes repair manuals usuall have wiring diagrams in the back of book.Around $20.
Posted on Oct 16, 2009
2002 monte carlo steering wheel and cruise control wiring diagram
Is the air bag light lit on the instrument cluster ? Clock spring inside top of steering column , under steering wheel .
How Clockspring Works
Apr 27, 2018 | 2002 Chevrolet Monte Carlo
1987 Suzuki TS 125 X wiring diagram
Hi, Brian for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Suzuki Motorcycle Wiring Diagrams
1987 Suzuki TS 125 wiring diagram Google Search
Suzuki TS 125 XE XF XG XH 84 87 Service Manual Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 14, 2017 | Suzuki Motorcycles
Trying to remove the ignition key switch from my 1987 nissan stanza, the release button does not work so need to remove switch to carry to locksmith
mcdevito75 here, On most cars once you remove the ignition key it also locks the steering wheel, try to move your steering wheel while pressing the release button to remove the key.
Jun 16, 2010 | 1987 Nissan Stanza
1997 Oldsmobile Achieva No brake lights or signals, fuse keeps burning out No power running through wires to rear brake lights, but Headlights/running lights work. We think short is in the steering wheel...
The problem is the flasher selector below the steering wheel in the column.The main copper arm is not touching the 4-5 contacts due to fatigue.Bend it down, OR the unit is sloppy due to plastic hooks holding it being fatigued.(most likely issue)Drill a hole in from side nearest key to push the hook tight against selector.Use a bolt with a nut outside and inside, apply glue so nuts don't turn.
Unplug battery for at least an hour (overnight better)to discharge power to air bag(best left that way while working on steering wheel). 2 screws behind horn/airbag unscrew them pull panel off, disconnect air bag wire. Disconnect the horn wire.You will need 2 types of wheel pullers after you take off the centernut.(Rent from Autozone) Remember the order of uninstall.(Washers inside)
Mar 02, 2010 | 1997 Oldsmobile Achieva
Airbag light continually coming on even after dealer has reset it twice now it wont pass inspection is there a way to reset it myself??
yes but your are better off to fix the problem once and for all underneath your steering wheel is the problem its called a clock spring or ribbon it has all the wires to your steering wheel accessories easy to replace remove the steering wheel,and you will see it, wire breaks inside the ribbon from all the winding and unwinding motion replace it all your problems will be solved for long time.
Jan 19, 2010 | 2006 Suzuki Grand Vitara
1991 Suzuki Sidekick instrument lights won't work
Try replacing the instrument cluster dimmer knob to the left of the steering wheel. It has been the cause on a couple of my samurais
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Aug 07, 2009 | 1991 Suzuki Samurai
Headlight problem suzuki forenza 2005 low beam headlight and day running lights no working fuses and relay are ok.
You probably need a new combination switch, located in the steering column, integrated into the control lever for lights. Remove airbag (if you have one) and then pull off steering wheel to access switches. We bought ours at you-pull junkyard, but I believe AutoZone also carries them for far less than dealer price.
Dec 25, 2008 | 2005 Suzuki Forenza
No head lights! HELP PLEASE!!
Probably the combination switch, located in steering column, controls all lights. On ours, we lost all lights EXCEPT headlights, fuses and bulbs were all good. Replaced the switch yesterday (well, our Sidekick had two switches) and now all lights work fine. You need to pull the steering wheel to get at the switches. We got parts at a junkyard, but AutoZone also sold them at less than dealer prices.
Dec 14, 2008 | 1987 Suzuki Samurai
Brake lights not working
I had the same problem, the brake light circuit runs through the column and through the turn signal switch and the contacts are most likely corroded. You will have to take the steering wheel off but be sure to disconnect the battery and let the car sit for 5min before taking the air bag out. Once you get the steering wheel off
you will take the screws out of the signal switch assembly, once done you will see two torks screws holding the switch cover on inside are the contacts. Clean the contacts with emory clothe and contact cleaner. The Cutlass series are notorious for this problem, you will need a friend to put the steering wheel locking plate back on because of the heavy spring load. I hope this fixes anybody with the same problem.
Sep 25, 2008 | 1994 Oldsmobile Cutlass Supreme
Electrical Supplies Logo
64 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
