Question about Sewing Machines
Laptop will not turn on after a restart, power supply is ok.with the battery in nothing happens when i press the on button if i connect the power supply i get a blue mains light on the front but nothing changes.
    New Friend:
  • 11 Answers
Change your batteries, maybe you picked already used batteries without knowing
Posted on May 18, 2014
The RCS Unit powers on but I cannot use any functions. When you press the buttons, nothing happens
Inside the machine there are many parts that have wires connected together. If one of them have been taken apart by accidental bumping it may cause this. By carefully opening up the machine and looking you may see the problem. However, touch yourself to some metal before messing with it. It is a better idea to let a pro take care of it.
Jun 28, 2016 | Janome MB4 Four Needle Embroidery Machine
How to restart my machine when there is a erorr
Does the light come on? It is worth checking that the leads are secure in the foot pedal, the machine and the power point. Also try a different power socket. If that does not work and you are in the UK you could check that the fuse in the plug is OK.
Feb 06, 2015 | Sewing Machines
My designer diamond gives me a message that machine needs to rest ,but I have not used it in over 24 hours. I press the ok button but it continues to give me the same message.
It is either the motor that needs replacing or the power supply. I've seen both. There is an updated power supply that was recently recommended by Viking. These parts should still be covered by the Manufacturer Warranty (provided you are the original owner and purchased from an Authorized Viking Dealer). Take the machine to an Authorized Viking Dealer. If it is still warranty, you should only be charged for the service/labor for the repair. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck. I know how frustrating this can be.
May 20, 2014 | Husqvarna Designer I
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Embroidery compontent wont move has computer first starts up
When the embroidery unit is not connected to the machine and you power up the machine it comes up in sewing mode? Holding the embroidery unit in your hand can you move the embroidery arm back and forth and the frame carrier back and forth? Is it very very easy to move or is there resistance? If its easy, probably a belt break. If it is very very hard, take it to a dealer at least for a learned opinion.
Nov 29, 2013 | Baby Lock Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Bernina 180 sewing machine 'died'. Was sewing - everything OK. Stopped to turn material, looked away, and when I turned back, screen, machine, everything was dead. Power source is OK. Exchanged cord -...
Hi, sorry to say but very rarely is it the fuse when this happens. You can unscrew the one screw on the ouside and pop the cover open. (carefull as there are wires attached and make sure you are grounded or have discharged any static from yourself).
The fuse will be self-evident but I suspect you will need a visit to your Bernina dealership for a new circuitboard.
Rick
Certified Bernina tech
Dec 06, 2009 | Bernina Artista 180
I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Aug 30, 2009 | Simplicity Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
