Question about Frigidaire Washing Machines
Why would my flse60rgs1 combo dryer not heat & washer won't start?
I have a frigidaire flse60rgs1 washer/dryer combo. All of a sudden the dryer stopped heating, but the drum spins (I have already replaced the heating coil) & here is the weird part - the washer does not work at all - unless the dryer is on and spinning, then the tub will fill with water, but will do nothing else. It is an all electric combo
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Posted on Mar 10, 2008
  • 3422 Answers
SOURCE: Front loader will not spin
You will have to get it repaired that's the only solution.
there being a bad connection wire between the motor and the control board.est the fuse(s) on the control board. If they are bad, then the control board is in need of replacement.
Goodluck,
Please don't forget to rate the solution
Posted on May 06, 2008
  • 3 Answers
SOURCE: Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Posted on Jun 12, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
My Frigidaire FLSE60RGS1 washer/dryer combo. the washer does not agitated it spins but doesn't do the washing movement stuff
Hi friend, I appreciate your post!
Based off the information you have provided regarding your Frigidaire laundry center it sounds like a possible problem within your control panel or agitator. Since it could be any one of these underlying issues I would recommend having a professional come out to your home to properly diagnose your washer. If you do not have a professional connection you can visit the manufacturer website to find a service provider in your area. Hopefully this is helpful. -Matt
Sep 24, 2014 | Washing Machines
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Grease leaking out from under adgitator
Hi and welcome to FixYa, I am Kelly. After looking at your model number the only source for the grease that your noticing has to be coming from the upper transmission seal. Unfortunately the seal is not listed as a single item for purchase. The only listing is for the entire transmission assembly. Item 3 this link:
. http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLSE60RGS1/1428/0152000/P0307249/00006?blt=06&prst=&shdMod=
The transmission part number is: 131878411 that is now superceded by PN 134736400
We used several screws in the seal and then wrap the screws with 0.020 lock wire to pull them out.
What really stinks is... this transmission seal can be replaced and can be bought at an automotive parts supply IF you have the sample in hand. The other problem anyone would have in replacing the seal is that you have to make a new gasket for the tranmission and discard / replace the gear oil in the tranmission once you open it. It is not a repair for the novice mechanic.
The agitator can be removed by taking off items 54 - 57 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLSE60RGS1/1428/0152000/P0307249/00005?blt=06&prst=&shdMod=
Here is a pdf file with all part numbers on pages 4 - 7 for this repait EXCEPT the upper transmission seal.
ftp://ftp.electrolux-na.com/prodinfo_pdf/webster/95375481.pdf
( I know that this manual is not 100 % exactly like your unit but the parts are 100% the same. )
Any other parts can be found on line here:
We replace our own UPPER grease seals vs the whole transmission assembly. It is always a very time consuming / labor intensive repair.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Washing Machines
Is there a reset button on Frigidaire stackable washer/dryer combo. Dryer will not come on, washer works fine. thanks
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 25, 2010 | Frigidaire Washing Machines
Frigidaire Washer/Dryer flse60rgs1 Starts filling but won't stop no matter what setting its put on it just fills the tub, and ultimately overflows
The problem is most likely the float switch or it could be a stuck fill valve. If it is the fill valve, it will stop filling if you unplug the machine.
You can find the parts and diagrams at partselect.com
If you need more help, post a comment.
Thanks,
Tim
May 14, 2009 | Kenmore 22642 Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
