Question about Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery!
My Drive Medical Phoenix 4 is all over the place. When I start out I have a full charge then after going 100 ft I start going to the yellow and then red. If I stop and turn off it will act as if it's fully charged again ten chart dipping to the red again. If I don't stop and turn off I will sit in the red untile red light starts blinking and the battery goes dead. I've had the pentiometer and throttle changed. Is there any way to fix this without getting a new scooter?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
Change the batteries. It sounds like your batteries are not able to hold a full charge.
Posted on Jun 20, 2014
5 Suggested Answers
  • 347 Answers
SOURCE: Battery isn't charging, no handbook
be sure of model etc & order a manul from the dealer,then once read the basic guides,if no joy then book will advise you to get in touch with a qualified dealer.
Posted on May 12, 2010
  • 692 Answers
SOURCE: I have a new Drive
soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Posted on Mar 25, 2011
drifterK
  • 4924 Answers
SOURCE: I just got my drive
I think you should try to leave the key into on position ..cause it may have a switch off function and not get the power flow right ..If in the manual says the fuse need to be on o position for charging ..leave it so ..if it says different set it on the correct position ..
The idea is to try all possibilities cause there is nothing you can do wrong ...when it starts getting the current it means it is the correct procedure..I found nothing about this specified but the key thing make sense somehow ..and it seam to be the only thing left to do ..Usually on these things , when it is plugged to charge it should indicate the charging ..and the led change color or lit the one indicating full only when it is ready for use...so .if the charging is not indicated without the key on ...it is a pertinent thought to consider to switch it on ..
Posted on Aug 07, 2011
gfreed100
  • 60 Answers
SOURCE: My Daytona 3 scooter does not hold the charge very well. Few minutes after a full charge (takes about 11/2 hrs to get the steady green light), the green light starts flashing and the charge indicator
Take your batteries out, and take them down to .a battery shop. Have the battery load tested, Reading the voltage under no load conditions will not tell you much, normally the batteries voltage gives you its state of charge. These batteries will show a full charge at no load, as soon as you put any load at all on the voltage drops off and you don't have much in amperage output. The amperage is what is important when you right down to it. When load testing your battery they will use an instrument that they punch in the cranking amps. The instrument will look for the voltage drop off at a load of what ever amp value you punched into the instrument. The instrument will give you a pass\fail indication for the cranking amps value the technician punched into the keypad. There can be a problem when load testing batteries. The technician doesn't key in a amperage value, This is what happened to me. The instrument when no value is entered will use a default value, Say the default amperage is usually set at around 200 Cranking amps. My technician was either rushed or just being lazy. He set the load tester to use the default values, my battery passed with the tester set up the way it was. My battery is a 35 amp\hr battery and puts out 480 cranking amps In actuality my batteries weren't putting out nearly that much. It would put out 265 cranking amps for about 2 seconds then die. He told me the batteries were good. When i brought the batteries back to him
i didn't let him take them into thee back room. THIS TIME HE DID THE CHECKS OUT IN PLAIN SIGHT OF ME. I asked to do a comparison between my batteries and new ones. We had to retest a number of time in order to find the upper limit of the new batteries. As it turned out my batteries were bad and all my problems disappeared with my old batteries. NOTE, scooters use deep cycle batteries only Glass mate batteries if you want to take your scooter on a flight.
Now if you had your batteries load tested and you know their good, its got to be the charger thats malfunctioning. Check the charger connection points make sure there tight. One connector should go to the negative battery terminal, the other connector should go too the positive terminal and read +24v. Make sure the connections are solid. Hope this helps
Posted on Aug 16, 2012
I charge the battery and mark it's full charge,but on the scooter the indicator don't mark is full charge and when you drive,the speed just suddenly will drop and come back ok.
Charging batteries to full means leave on charge for 12 -16 hours as it may show charged but the charger goes into what is called a battery conditioning mode where a small trickle charge takes place to fully charge batteries. Again, how old are batteries and have you had them load tested at all?
Jun 15, 2015 | Drive Medical Health & Beauty
My husbands Daytona 4 just started having this charging problem
I'm afraid your batteries have expired. They will show full voltage but the Amps are not being replenished.
Jun 18, 2014 | Drive Medical Health & Beauty
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
www.gewizrepairs.co.uk
Feb 01, 2014 | Drive Medical Phoenix 3 Wheel Compact...
My Phoenix scooter is two years old and looses the charge in about 5 min. I changed the batterys and got a new charger but it still does this?
hi, there must be a short, first of all is it possible you got another set of bad batteries, are they new ? and how long are you charging them for , and it the charging showing that it , if for some reason the connection is bad depending on the charger can show fully charged when it fact they are not !!! check the charger socket to the batteries...
Regards
GeWiz.
Feb 02, 2013 | Drive Medical Phoenix 3 Wheel Compact...
My scooter is too slow,the battery charges,but only drives at a very slow speed.While going backwards drives at a good speed.Can you tell what to do??Many thanks Diana Donald
Hi dianaidonald
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. Your problem is the throttle pot or somtime called the engager. or the speed pot.
1.. Replace the throttle pot and or (speed pot most likely the problem).
Good Luck
Tim
Apr 30, 2011 | Drive Medical Drive Phoenix 4 wheel...
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the...
Mar 25, 2011 | Drive Medical Odyssey Full Size Scooter
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
What is the tension on cylinder head bolts for a jeep grand cherokee 307935 4 litre, 6 cylinder, 1999, petrol motor.
Coat threads of left hand front bolt with sealant: 1st - step; - 22 ft./lbs. 2nd - step; - 45 ft./lbs. 3rd - step, all bolts except L.H. front bolt; - 110 ft./lbs. 4th - step, L.H. front bolt; - 100 ft./lbs. fig100.png
Sep 05, 2009 | 1999 Jeep Grand Cherokee
Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery! Logo
137 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
