Question about Dishwashers
Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
If I pour water in the drain, it clears it fine, but otherwise is just running dry. Tried to reset the dw, but nothing happens. Turns off with the on/off switch but starts doing this when restarted. Checked drain, not blocked. Tried to reset by resetting circuit breaker, but it did not help. I think is saw error code c3, then it shows PO with the regular wash light in solid and the quick wash light blinking. Thanks for any hep you can provide.
    Scholar:
  • 159 Answers
Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
Posted on May 18, 2014
Testimonial: "Thanks for the advice. Your answer got me to the solution. I could not find a free technical manual, so I started searching for stuck float issue with my model Bosch and found an answer that worked. Removed the bottom face plate and reached in with paper towels to dry the plastic pan-two wells were found by reaching in from the top. Drying this up released the float, and it restarted correctly. I'm not sure yet if this was only a temporary or permanent fix, but it's a start. Thank you for getting me on the right path and for responding so quickly. I have always gotten accurate quick responses from FIXYA. THANK YOU!"
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Drain cycle will not turn off - even when all the water has been drainged. Also stays on when opening the door.
pull the machine out and tilt it back, water may pour out from under the machine, if it does, it indicates that the anti-flood device has actuated, thats why the machine is continuing to drain constantly. leak some where underneath is the problem.
pallesappliancerepairs.com
Feb 03, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
318 people viewed this question
Top Dishwashers Experts
Owen Barnes
