Question about Acer Aspire One PC Notebook
Acer Aspire 1 only runs on mains - although battery is charged
I stopped using my Acer Aspire 1 for about 4 weeks. I have fully changed the battery but it will now only work with mains supply. Can you help ?
    Sergeant:
    Champion:
  • 253 Answers
Batteries should be conditioned before normal use by ensuring they are charged and then fully discharged for the first 3 to 4 charge cycles.
and for our technician help contact us at 18884276640
Posted on Jun 23, 2009
Acer Aspire 5734z-4725 battery not charging
If your laptop computer runs normally on the ac adapter, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
http://www.chargerbuy.com/replacement-acer-aspire-5734-ac-adapter-19v-90w-cord.html
Feb 22, 2013 | Acer Aspire 5315 Notebook
Acer aspire wont turn on
Remove main battery, power up! no change, remove one stick of ram and power on, if same problem! remove second stick of ram and replace the first one back in, any change? if no! I recommend a professional at this time to assess possible motherboard issues.
Mar 11, 2012 | Acer Aspire 7736 Notebook
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have 4 months with my Acer Aspire 5251-1513 and I have noticed 1 week ago that my battery will not charge to full capacity. When it reaches 79% it stays there and will not charge from there, what should...
your battery may have become "Imprinted".
Run the system on battery until the battery is completely dead, then fully recharge it as far as it will charge, then exhaust the battery again. If the battery doesn't recover it's full capacity, then contact Acer for a replacement as the battery should have a 1 year warranty
Jan 10, 2011 | Computers & Internet
My aspire one d-250 battery doent charge
My problem was: Although the Batt Light shows the "charging" the desktop indicators show the battery is at 100%. If you dscinnect the power supply the computer dies.
SOLUTION: I found this worked on both occasion it happened to me occasions.
1. Shut down the netbook.
2. Remove battery for +- 15 min.
3. Replace battery.
4. Do not switch on netbook, ie boot up, until charge light goes to green ie indicates fully charged.
Dec 28, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5050 I bought a new battery . My laptop works fine on Ac power but when I installed the battery it shuts off immediately
I apologize that I am having a hard time following the thread as to what you have tried and so forth. I will assume the following:
1. You have an old battery that does not hold a charge but the laptop does run with this battery installed, from AC or from AC w/no battery installed.
2. You have installed the new battery (with the laptop off) and it does not run from the battery or when plugged in.
3. You have tried charging the new battery 4-6 hours.
4. You are using the original charger or one that is fully rated for the laptop - I think this needs a 90W.
New question: does the charge light come on?
If the above are all true then there are 2 possible problems:
1. Bad (shorted) battery - this is possible, although unlikely, fro a new battery.
2. Power connection on the motherboard is faulty. The center pin may be loose, thus not giving full power to the system to charge the battery and run the laptop at the same time. This should be "overcome" by charging the battery w/system off. OR, the connector is like a headphone jack in that when you plug in, the primary connection is opened but on this series of laptop I have seen this fail.
Try powering up with the battery in and adapter plugged into the laptop but not to the wall.
Let me know what you discover. Reply w/my name so I know which thread to read.
Jon
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire Computer Does not Turn on
The light you are seeing usually is a sign that the battery is discharged. Although you say the battery shows that it is fully charged, it is possible that the battery is fully discharged or defective. You should disconnect the battery from the pc and try powering on with the ac adapter. Although no way to per say "force reboot," removing all power sources (ac adapter and battery) should in essence reset the motherboard.
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Acer Aspire One  PC Notebook Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
