Question about Kenmore HE2 Plus Front Load Washer
Drum clicking when the drum rotates clicks bad
    Scholar:
  • 159 Answers
Something small like nail , Bobby pin , more than likely it will be too big to fall all the way through the drum but you need to find it before it causes bigger problems.
Posted on May 18, 2014
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
Kenmore dryer won't come on but make a low buzzing
Motor is not running. Could be bad motor (or motor capacitor, if one), or the blower, belt, drum are not free to rotate. With the power off, reach in to turn the blower wheel, motor, belt, or drum to make sure they are not bound. If free to rotate, investigate the motor.
Oct 17, 2014 | Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 17, 2011 | Maytag Dryers
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
How do i get back brake drums off of a 1992 buick lesabre?
try hitting the face of the drum with a large hammer until free from hub rotating the drum as you go. you may have to de-adjust the rear shoes once the drum is free from hub start by removing the oval shaped rubber plug for the adjustment window on the backing plate with a flat head srewdriver or brake adjusting tool and a small pick to push the anti reverese lever back rotate the star wheel oposit of the audible cliking. clicking is tightening once de-adjusted enough rotate and pull the drum off.
Jul 25, 2009 | 1992 Buick LeSabre
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Model LEQ9858PWO Whirlpool Electric Dryer-- Wife heard a clunk.
Your wish came true, DS! Click here and browse through the sub-components section.
Your lucky day,
SG
Apr 06, 2009 | Whirlpool LEQ9858P Electric Dryer
How to remove the rear brake drum on a 1999 chrysler town & count
The star wheel is accessible after removing the elongated rubber plug on the drum housing right next to the brake bleeder screw. Use a "brake drum spoon" to rotate the star wheel one click at a time. The proper direction of rotation is the direction the star wheel does not want to go since you are turning it against the hold of the ratcheting no-back. After rotating it several clicks, jiggle and pull on the brake drum and if it doesn't slide off with a normal amount of force, rotate the star wheel several more clicks. If I recall, the star wheel only has about 25 clicks of rotation or so before even brand-new, thick shoes are backed off away from the drum a significant amount to the point that the auto adjuster has a considerable amount of slack in it (no outward pressure).
Feb 27, 2009 | 1999 Chrysler Town & Country
Kenmore HE2 Plus Front Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
