Klipsch Subwoofer sub10 power supply problem in India
I have a klipsch subwoofer sub10.
In the user manual it is clearly written that the
subwoofer should be supplied with the exact power
supply specified in the back side of the unit. It is
specified as 230V 50Hz, 1.0 A.
How can I get a proper power supply mentioned in
India?
The subwoofer is down. No response. No LED. But electric shocks observed on the screws in the backside of the speaker when I touched them.
I trying to figure out the reason. This is serious becos it is the second time. First time happed just 10 days from the date of purchase. I got a replacement. This secod one worked well for 4 months and facing the same problem again. I doubt it is becos of the improper power supply against the spec. Please help me in this problem.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
As we know in India power goes on and out all day. so avoid using any extensions
Posted on Mar 18, 2017
5 Suggested Answers
SOURCE: klipsch subwoofer
call Dr. Korvorkian! He will help.
Posted on Jan 07, 2008
VOTIT
  • 2071 Answers
SOURCE: My Klipsch synergy subwoofer not working
No sound problem is power amplifier trouble maybe the IC there is defected or cold solder of joint of the parts.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Don't forget to rate;
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: my amp overheated on a Klipsch promedia 2.1
Sounds like your speakers had too many watts sucking from an amp that couldn't produce the power to feed them.
What is the max watt power output rating for your amp?
Compare the amperage of all the speakers combined and make sure they are 15% lower that the rating on your amp. Be sure to include the sub in your totals.
Chances are you've blown the power supply on your amp.
Have you tried any of these checks yet?
Posted on Dec 14, 2009
SOURCE: Klipsch/KLIPSCH, not BOSE, pleaz HELP!!! -ifi wont play anymore
It sounds like I'm in the same boat as you guys. I just wonder if I can do this repair by myself. I have limited electronic experience. If it is just a matter of pulling out "x" and replacing with a new "x", I can handle that... but will I need to solder?
Posted on May 08, 2010
Klipsch sw 350 subwoofer not working in auto on off position
The audio signal on the subwoofer output of your amplifier turns on the subwoofer after a brief delay to prevent "popping". Sometimes you have to crank up the gain to turn on the sub, then turn it down to a comfortable level. If this approach does not produce results, there may have been a component failure in the input circuit.
Jan 14, 2014 | Klipsch SW-350 Subwoofer Speaker
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Klipsch cs-700
my klipsch cs 700 subwoofer not work
Jul 19, 2012 | Klipsch Audio Players & Recorders
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
305 people viewed this question
 Grubhead
Grubhead
