Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
Magic Chef #HMCF7W1 should the green light go off?
The green light goes off, is this right
    Scholar:
  • 73 Answers
Same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
Posted on May 22, 2014
Holiday chest freezer lcm070lc
There are only three wires, aren't there? One is a safety earth, probably green or green and yellow. It goes on the spade attached to the metal of the thermostat body. The other two are a live and switched live. They go on the two spades that come out the plastic body. If there happens to be a third, it will be an alarm signal wire. Connect in any order you like. If the compressor comes on and the signal light, all is well. If the signal light does not come on, and the compressor switches off at -12c swap 2 of them. If none of this happens, switch 2 of them.
Apr 21, 2014 | GE Freezers
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Does it mean any thing if the freezer light is yellow
No. It could be green, red, white, IR, and colored light will work if it's the right wattage and the same bulb barrel, then it will workie...he,he,he,he, awesome colored lights in one freezer---never though of that before, wonderful...GB ya. stewbison
Aug 20, 2011 | Frigidaire 9 cu. ft. / 255 liter Chest...
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
285 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
