SOURCE: where is the resistor for
under the dash on passenger side. take the under dash pannel off and then you should be able to see it. its put in a hole in the heater/ blower motor case and has a 4 wire connector, unplug connector and then remove resistor.the wire colors should be 2 black and blue wires 1 black and yellow and 1 black.
SOURCE: 1998 ford contour blower motor not working
I have a 1998 Ford Contour. Believe it or not the ABS and the Blower Motor share the same fuse. It's a yellow 60 amp and you have to take off the battery to get at it. Of course this happened twice in the 6 years I had the car, both times in the dead of winter. Tires Plus in Pennsauken, NJ replaced it. Other than that, no complaints with my Contour.
SOURCE: 2006 Ford Explorer XLT the Blower Fan only works on 4 and 3 Sp
Look under the dash on passenger side and just to the left of the blower motor housing you will see the 4WD control module.Remove the 2 screws holding the module and let it hang down and your resistors are behind this.Remove the 2 screws holding the resistors and remove.
Now I am assuming you have manual climate control and not electonic.
SOURCE: where is the resistor in a 2001 ford explorer
You have to remove your glove box and it is behind there. Here is a picture of where it is. This particular picture is from a 4 X 4 so if you don't have that it won't have the 4X4 part. Let me know if you have any more questions. Thanks for using FixYa!
SOURCE: where is the blower motor resistor located on a
On Your Truck Im Not 100% Sure But Most Are In The Heater bow Right Behind The Glove Box
