Question about Dirt Devil Rampage Robotic Pool Cleaner Vacuum
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
  • 41 Answers
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
Posted on May 18, 2014
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: my dirt devil Rampage Robotic pool cleaner vacuum
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Posted on Jul 20, 2011
jharwell668
  • 640 Answers
SOURCE: cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Posted on May 19, 2010
Find parts for pool girl
Hi! Those pool toys are actually manufactured a different company. You can get in touch with them at /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman","serif";}
May 01, 2014 | Dirt Devil Pool Vacuums: Pool Girl...
My pool cleaner seems to have to much bouyancy
Set a brick or weight on top of it and tie the brick/weight to the vacuum. that might help it.
Nov 17, 2013 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt devil pool vacuum slow stays on pool sides
go to http://dirtdevil.com/support/ get the support section and download manual, troubleshooting, video for troubleshooting, and fix it.
God bless you
Sep 16, 2012 | Dirt Devil Vacuums
Automatic cleaner won't do the whole pool? Keeps skipping big patches?
use the diagnostic system in accordign with the inst.manual or download free www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jun 19, 2012 | Dirt Devil Rampage Robotic Pool Cleaner...
Replacing the drive track.
The tracks for the Dirt Devil Rampage pool cleaner are the same as the AquavacTigershark. Simple look for the parts for the Tigershark. Its the same exact thing.
Jun 20, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt Devil R088100. Cloth Was Sucked Into Hole Below Dirt Holder
Brad, Hopefully it is the belt that you smell burning. I would start by removing the underneath side of the vacuum head. Normally just a few screws that are meant to be remove for general maintanence and circumstances such as this. After removing the screws this should reveal the dirty side of life to you. You may need to remove the roller brush, and inspect the ends to make sure the brush rolls freely while holding the ends. If not the ends may need to be cleaned of hair and strings: ends should pop of and a shaft runs through the middle connecting them. Clean and replace. Move on up the path the dirt travels. The neck where the head and vacuum come together is the next jamming point, if this is where the cloth is lodged chances are the motor may have over heated due to clogging. Your vacuum may have a automatic shut off. You will need to contact Dirt Devil to see if there is a reset for the motor. There are propellers / fan blades at the end of the neck just before the motor housing. This is most likely where the clothe has logged itself causing the brushes on the electric motor to emit the burning smell, if you can remove all obstructions and the unit still does not turn on, check with dirt devil about the reset, Hope this helps.
May 25, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Cleaner is not picking up debris from pool bottom
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
My vacuum is making a horrible noise!
I solved my own problem. I bought a new vacuum.
Aug 13, 2007 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil Rampage Robotic Pool Cleaner Vacuum Logo
163 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
