Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
My Inglis Refrigerator doesn't make ice anymore,
The ice maker in my Inglis fridge does not work, I have checked inside the fridge, the wire is down, the fridge is cold enough to maintain ice in the ice tray; there is plenty of water flow in the water dispenser, I don't see any water coming to the ice maker.
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Posted on Nov 24, 2009
My ice maker is not bringing water up to make the ice
Pull the refrigerator out from the wall so that you can get behind it. Make sure that the faucet is turned on. (You might to desonect the fitting from the faucet to make sure that water is coming thru the faucet.) Assuming there's water there, follow the water line to the fridge, checking for any kinks that might stop water from flowing. There may be a panel down below that needs to be removed. Check the connection to the fridge. there might be a shut-off valve there. Make sure that's turned ON. Most fridges have the water line exposed on the back of the fridge. Follow the line , again checking for any kinks. Now the line goes inside the freezer. Make sure the connection is secure. Now, on most ice makers there is a box on the front of the icemaker that's removable. Inside is the switch that varies the size of the cubes. There also might be an on/off switch. Make sure it's on. That's it from me. Good Luck!
Jan 16, 2014 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Ice maker working very slow
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects then you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | LG 25.2 Cu. Ft. Side By Side Refrigerator...
Ice maker does not make ice,water pressure seams to be good enough and the wire lever is down
imufo2
Leo Ponder
Jul 26, 2011 | Maytag MSD2456G Side by Side Refrigerator
In door ice maker not turning
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kenmore Side by Side Refrigerator
Kenmore side by side Model #106.53532300~~~Ice maker stopped working????
Leo Ponder
Jul 06, 2011 | Refrigerators
Ice maker has stopped working.
Leo Ponder
Jul 01, 2011 | Whirlpool Ice maker 4317943
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
Ice maker not working
Check the following:
* Water supply to the fridge
* Open the freezer compartment and check to see if the water inlet fitting is frozen. It can be thawed out with a hair dryer....carefully
* If not the above, check the water valve, usually located on the lower back of the unit behind a cover. It may be malfunctioning or is plugged with debris
* Make sure the stop arm of the ice maker (inside the freezer) isn't stuck in the up position
Apr 27, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Refrigerators Logo
942 people viewed this question
Top Frost Refrigerators Experts
Charles T Nevin
Charles T Nevin
Mike
old fart58
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
