Question about Car Audio & Video
If rear door speakers are knackered, can i extend the wire form the rear door and fit kenwood 6by9 into the parcel shelf xx
    Problem Solver:
  • 13 Answers
Yes u can but it depends what kind of power output your head unit can handle.
Posted on Jun 14, 2014
    Habit-Forming:
  • 79 Answers
Yes - assuming you are talking about putting a pair of speakers in the back (left/right) similar to the way the rear door speakers were originally installed.
When you are extending the wiring, you will want to make sure that you make sure the connections are done well - I would recommend cutting the existing wires to expose "fresh" copper, then soldering these together and wrapping with electrical tape.
Also, note the polarity (+/-) all the way to the new speakers - if you get this mixed up, it will have very weak bass - and you can swap the inputs to the speaker to correct.
Note: bad connections are the #1 issue for car stereo systems since the vibration and moisture are not kind to electrical circuits.
Posted on Jun 13, 2014
  • 231 Answers
SOURCE: peugeot 106
you could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Posted on Dec 08, 2007
  • 50 Answers
SOURCE: 6 by 9s
you will have to make a 6x9 templet and them you will have to cut it out.
Posted on Jun 20, 2008
j_del
  • 1586 Answers
SOURCE: 1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Posted on Dec 17, 2008
  • 38 Answers
SOURCE: i am about to put
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Posted on Jan 31, 2009
budice7h20
  • 93 Answers
SOURCE: Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
How do you remove rear speaker covers in a 96 geo
are they fitted in the rear doors or the parcel shelf ,if there aree no visable screws to un do if door fitted then will have to remove the door panel , if on parcel shelf same thing if no screws visable then remove from underneath , hope this is of some help
Sep 29, 2014 | 1996 Geo Prizm
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
May 18, 2014 | Kenwood KDC-MP538U Car CD/ MP3 Player
Where is the parcel shelf on a 2007 Mini Cooper
The parcel shelf is that flat area behind you head of the rear seat. Normally has speakers or junk on it. On hatch back cars it lifts up as you open the hatch.
Mar 28, 2013 | 2007 Mini Cooper S Convertible
How do you remove the rear speakers from a 2004 chevy impala?
Remove the rear seat. On later models remove the rear upper quarter panel by pulling down & out to disengage the retainer clips, then sliding the roof leg out from under the trim panel over the door. Detach the rear seat belts through the slot in the rear parcel shelf. Pry up the plastic clips securing the rear parcel shelf. Then lift up & out to remove it from the vehicle. Remove the speaker retaining screws or tabs. If the speaker seal has bonded with the metal shelf, hold the tabs & pry the housing away from the metal. Disconnect the electical connector & remove the speaker. Install in reverse order. Good luck!
Feb 22, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
How to remove the rear speaker panel for a 1997 dodge neon
Remove entire rear seat assembly
Pry out the rear portion of the seat belt trim bezel.
Partialy remove the rear parcel shelf trim panel, slide it down and out of the way.
Remove the screws and detach the speakers.
Installation is reverse of removal, making sure that wire connectors face toward the center of the vehicle
Dec 30, 2009 | 1997 Dodge Neon
Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
May 02, 2009 | GMC Jimmy Cars & Trucks
Need to install radio
This maybe due to the fact that all manufactured wiring harnesses installed in the corolla are standard looms, you will probably find that you do not have rear speakers installed, however the wires are located beneath the speaker grill by the parcel shelf. the standard corolla stereo only uses front speakers,but the loom has the ability to connect 4 speakers.most manufacturers always fit 1 standard loom as it is cheaper to install a full loom than make variations for different specs and models.check your stereo to see if it is used with 2 or 4 speakers. regards neil
Aug 02, 2008 | 1998 Toyota Corolla
Changing Rear Speakers in a 1996 a4.
First remove the rear seat bottom cushion (grab the front edge roughly in the center of each seat position and pull up firmly, and it'll unclip and come out). Then fold down the rear seatbacks. Now, the side bolsters for the seats (between the seatbacks and the doors) have to come off. First, pull down strongly near the bottom (there's an upward-facing hook there that clips onto a ring and holds the bottom in place). Pull down and forward and it'll come off. Then slide your hand about 75% of the way up, and pop the bolster straight forward to pop out a retaining clip. Finally, you can remove the top of it from its mount, and you'll have the bolster out. Repeat for the other side.
Go into the trunk and look up at the bottom of the rear shelf. The harness plug for the third brake light is there - unplug it.
Now, back in the rear seat area, just grab the front edge of the parcel shelf and lift upward to pop it loose, and the whole thing will slide forward. Then you can remove your speakers.
Install is the reverse of disassembly.
Jul 30, 2008 | 1996 Audi A4
Peugeot 106
Dec 08, 2007 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
6x9s in a clio
forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
Dec 04, 2007 | JBL LC-S960 Car Speaker
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
