Question about TPI E4315T Wall Mounted Panel Heater
When I turn the unit on it clicks but fan doesn't move?
What could be the problem? It's our only heat source at our work place so trying to find a solution. Worked fine last night, went to turn it on this evening and this is what happened.
  • 25 Answers
I have fix fans by lubricating the shaft there is usually a support that get gummed up and it will not hurt putting wd 40 in an electric motor otherwise the motor is bad or the overload burned out every electrical motor has an over load where it is heat (thermal) or others i can not think of right now some are fixable by replacing a diode
Posted on May 18, 2014
LR-350 keeps on turning off
Check the wiring for the fan and the temperature sensor. If the fan isn't running/broken the unit will not start or ignite. Try moving the fan blades with the unit unplugged. If they don't move easily or are ceased the fan may need replacing or lubricating. The heat in these units dries out the fan bearings over time.
Dec 13, 2014 | Heating & Cooling
Over heating hdd
Desktop or Laptop ?
Computer technology moves quickly, with laptops having become faster and capable of doing a lot more over the last few years.
The main problem with running powerful components is that they build up a lot of heat that needs to be dispersed.
Due to the compact design of most laptops, heat buildup can be a problem that often leads to system crashes or even worse, damage to the machine.
It is therefore important to maintain your laptop so that it can efficiently cool itself.
Adjust your Windows Power Management setting to "Portable/Laptop."
This can be found in the Control Panel under "Power Options."
Turn off your laptop and clean the fan vents with compressed air.
The vents can be found on the bottom, sides or back of your laptop, depending on the model.
Raise your laptop to keep air flowing underneath.
You can buy a commercial pad to do this, but propping up your machine with household items by an inch achieves a similar effect.
Keep your laptop in a cool environment when it is in use.
An air-conditioned room is ideal, but if this is not possible, avoid exposing your laptop to unnecessary heat sources, such as direct sunlight.
Shut down your laptop when it is not in use.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Laptop fans are designed to keep the system cool by removing heat from the hard drive, processor and other internal hardware components.
The fan draws cool air in, then blows hot air out through vents in the laptop case.
A faulty laptop fan can cause permanent damage to occur very quickly.
If a laptop fan starts making loud noises or stops blowing hot air through the vents, replace it as soon as possible.
Turn the laptop off and unplug it. Unplug or disconnect any external drives or other devices.
Move the main battery latch to the "Unlock" position and remove the battery pack.
Push in on the optical drive release mechanism, then pull the CD/DVD drive out of the case.
Remove the screw(s) that hold the hard drive sled in place, then pull the entire hard-drive assembly out of the case slot.
Turn the laptop over.
Remove the screws on the bottom that hold the keyboard assembly in place.
Flip the laptop over then open it.
Lift the front of the keyboard up about 1 to 2 inches.
Unplug the flexible ribbon cable that connects the keyboard to the motherboard, then pull the keyboard assembly away from the bezel.
Lay the keyboard aside.
Unplug the laptop fan. Remove the screws that hold the heat sink/fan assembly in place, then remove the fan from the laptop.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
http://www.youtube.com/watch?v=Bwr3vxSErs0
How to fix an overheating laptop : Clean your fans and heatsync with this procedure
http://www.youtube.com/watch?v=ZXd09C0p-Cc
How to clean a laptop fan
Aug 08, 2013 | Toshiba Computers & Internet
My laptop is overheating.why?
Computer technology moves quickly, with laptops having become faster and capable of doing a lot more over the last few years. The main problem with running powerful components is that they build up a lot of heat that needs to be dispersed. Due to the compact design of most laptops, heat buildup can be a problem that often leads to system crashes or even worse, damage to the machine. It is therefore important to maintain your laptop so that it can efficiently cool itself.
Adjust your Windows Power Management setting to "Portable/Laptop." This can be found in the Control Panel under "Power Options." Turn off your laptop and clean the fan vents with compressed air. The vents can be found on the bottom, sides or back of your laptop, depending on the model. Raise your laptop to keep air flowing underneath. You can buy a commercial pad to do this, but propping up your machine with household items by an inch achieves a similar effect. Keep your laptop in a cool environment when it is in use. An air-conditioned room is ideal, but if this is not possible, avoid exposing your laptop to unnecessary heat sources, such as direct sunlight. Shut down your laptop when it is not in use.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Laptop fans are designed to keep the system cool by removing heat from the hard drive, processor and other internal hardware components. The fan draws cool air in, then blows hot air out through vents in the laptop case. A faulty laptop fan can cause permanent damage to occur very quickly. If a laptop fan starts making loud noises or stops blowing hot air through the vents, replace it as soon as possible.
Turn the laptop off and unplug it. Unplug or disconnect any external drives or other devices. Move the main battery latch to the "Unlock" position and remove the battery pack. Push in on the optical drive release mechanism, then pull the CD/DVD drive out of the case. Remove the screw(s) that hold the hard drive sled in place, then pull the entire hard-drive assembly out of the case slot. Turn the laptop over. Remove the screws on the bottom that hold the keyboard assembly in place. Flip the laptop over then open it. Lift the front of the keyboard up about 1 to 2 inches. Unplug the flexible ribbon cable that connects the keyboard to the motherboard, then pull the keyboard assembly away from the bezel. Lay the keyboard aside. Unplug the laptop fan. Remove the screws that hold the heat sink/fan assembly in place, then remove the fan from the laptop. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. http://www.youtube.com/watch?v=Bwr3vxSErs0 How to fix an overheating laptop : Clean your fans and heatsync with this procedure http://www.youtube.com/watch?v=ZXd09C0p-Cc How to clean a laptop fan
b>
Mar 01, 2013 | Computers & Internet
Need help with my advent 7082 laptop. hot and turning off.fan not working.got new fan.fan still not comeing on
These might not be your particular laptop it might give you some insight on how to fix the problem
Jan 29, 2013 | Computers & Internet
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
My PS3 shuts off by its self after a few sec fan still work and this just started
It may be that the unit is over heating. I suggest you move it away from any other source that creates heat and then try it again.
Dec 25, 2011 | Sony Playstation 3 80GB Game System BluRay...
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
TV cuts itself off
It may be overheating. Check the temperature with your hand by placing it over the fans/slots to feel for any excessive heat. If it won't turn back on until it cools, then it's a heat issue. You could help that out by using fans to circulate the air around the unit, trying to keep it cool by moving the hot air released from it and pulling in cooler air. Other than that, there may be a short somewhere, or maybe even a broken fan.
Jun 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Fan whining and blades not going
Sounds like your compressor outside is frozen up or (locked up) the smell is outside correct? it could also be your fan also in your condensor unit outside the easiest way is to listen for fluid movement (if your freon is moving then your compressor is working and you need to lean toward a fan motor. check to see if you can move the fan blades in the compressor (outside ) if the problem is in the house then approach in the same way with the power to the unit turned off only If you cannot turn it most likely fan motor replacement is in order, and pressure sensors are not letting your condensor run. theres a few things to try hope i have helped .Honestly it probably would not hurt to let a service man look at it anyway, but this way at least you're a little wiser chris
Jun 12, 2009 | Goodman CLT36AER36 Air Conditioner
LASKO model 5400 ceramic heater
The contact are just a set of points. If you can remove them, file or sand, or whatever will do the job, a little on the place where the contacts touch. Usually that's all it takes. Make sure when the switch is turned on the lever/spring assembly moves and at least tries to make them touch. I don't really see a problem with directly wiring the fan. The only drawback is there is no real control except pulling the plug.
Mar 02, 2008 | Heating & Cooling
TPI E4315T Wall Mounted Panel Heater Logo
Top TPI Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a TPI Heating and Cooling Expert? Answer questions, earn points and help others
