Question about Makita 10" Miter Saw LS1030N
Where does the spring go in the blade guard for a makita miter saw
SOURCE: makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Posted on Dec 15, 2008
rowdy45176
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
rowdy45176
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Posted on Feb 03, 2010
rowdy45176
  • 2176 Answers
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
Posted on May 04, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Posted on Jul 12, 2011
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
May 01, 2011 | Makita 10" Miter Saw LS1030N
The spring in the blade guard came out while replacing the blade
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist you. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Dec 14, 2010 | Makita 10" Miter Saw LS1030N
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do I install the spring after changing the blade on the Makita 10 miter saw
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Apr 10, 2009 | Makita 10" Miter Saw LS1030N
Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Jan 01, 2009 | Makita 10" Miter Saw LS1030N
Makita ls1013fl I need instructions on how to install
Joe
Dec 14, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita 10" Miter Saw LS1030N Logo
60 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
