Question about Bryant 561CE060-A 561C Package Air Conditioner and Condenser
My Bryant 561c airconditioner I need to know what wires to attach to my outside A/C is it blue on blue and yellow on brown
    New Friend:
  • 63 Answers
Brown is always active, blue is always neutral. But yellow or yellow/green is usually an earth. Sometimes on appliances yellow is used as a signal wire so if that is your only option then I would just run with that. If you trip your circuit breaker after turning it on then it was a earth and your back to square one
Posted on May 17, 2014
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
I am trying to install an aftermarket stereo radio/cd into a 1989 Holden/Isuzu Australasia
its easier to try an get a multi plug so you just connect them
Dec 15, 2016 | Cars & Trucks
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
On a bryant air conditioner I am trying to hook up the capacitor (60uf/5uf/440vac) that is a replacement.I have two yellow wires,one brown wire and one blue wire.Which goes to herv,fan and c
On the top of the Capacitor if you look closely H(Compressor) C(Common) & F(Fan) will
be stamped on top of capacitor. You will have to follow the wires back, my guess is blue
could be the compressor, yellow probably the fan and brown the common. the to yellow
wires are probably hooked to each other and can be changed if the motor starts up the wrong
way. Follow the wires back to each component to double check
Aug 31, 2011 | Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
Need to know what the wiring diagram is for a ar30-1 airconditioner, for a home
Sounds like a Goodman A/C. Wires R red Y yellow cool W white heat Green FAn Blue or brown will be common. O or orange if heat pump goes to orange outside unit.
May 08, 2009 | Heating & Cooling
Bryant 561CE060-A 561C Package Air Conditioner and Condenser Logo
218 people viewed this question
Top Bryant Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Bryant Air Tool and Compressor Expert? Answer questions, earn points and help others
