LC320EM8 lines on screen going up and down on three spots on this set anyway to fix it?
    New Friend:
  • 63 Answers
Nope. Time for a new one. You could get it fixed but that would cost as much as a new unit.
Posted on May 17, 2014
2 Suggested Answers
SOURCE: getting lines in my picture
the problem i have with my samsung lcd tv, as soon i put it no,instantlly it will toun off. what do u think is the problem? send me a mail matayo4life@yahoo.vom
Posted on Dec 20, 2008
My Vizio has three white lines running down the screen. Is there anyway I can fix this issue myself
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line fault to the most of the LCD TVs will be similar; irrespective of its brand name and screen size.
Feb 16, 2015 | Vizio Televison & Video
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Hi I have a Panasonic 36" TXPF10 TV. THERES different colors on the screen like a SPECTRUM, is there anyway of fixing this
Its what we call a purity problem on this 36 inch set and only two things cause it, the set (not getting too technical) uses a single part connected inside that when set is turned on powers a large coil around the picture tube--it just demagnetizes the tube---what happens is there is a single black square part there not much bigger than a cube of sugar---easy to spot as it will have three leads in a triangle shape---
What you will likely find if you can get the set apart---Its a real heavy set is follow the power cord to the board---real high chance you will find one of the three leads on that part has broken loose from the board, happens from all the heat at turn on that part gets real hot for a very short time.
You would be smart if one lead has come loose to solder all three---the part is often referred to as a thermistor--as it gets hot it cuts voltage off to the coil.
The other possible cause is only possible if set fell forward or was dropped, in that case the damage is fatal and cannot be repaired.
Let me know if questions.
Dec 11, 2012 | Panasonic TX-36PF10 TV
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
Hitachi 53" projection
there might be some resistor that shorted
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Satellite A135 Display
Unfortunately you have permanently put a thumb print on your screen. Diagnostics will not fix this.
Jul 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Three colors line up on some spots but not others
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Hitach 52" rear projection tv
The problem you have with the picture is a problem with the video circuit. Most likely a coupling capacitor or the Y/C Video Jungle IC. the half mood on the picture could be a seriuos problem though. You will need to take off the front screen and while the set is on, look down all three picture tubes. Is there what looks like a spot on one of the pictubes surfaces? If there is, that tube is going to have to be replaced. If it looks like something floating around inside the tube, maybe the tube can be disassembled and cleaned.. Also check the mirrors inside the set and on the surface of the three lens, maybe there is a spot on one of those. Good Luck.
Mar 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
