Question about Sentry Fireproof Safe
Why won't the bolts on the left hand side of my sentry so310 safe not retract when the safe is opened, now I can't close my safe?
  • 25 Answers
I just got robbed june last year the safe just let them know what to take put private stuff in a night stand or storage ben of some sort
Posted on May 17, 2014
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
http://www.sentrysafe.com
the instructions are located link above.
mj
Posted on Sep 07, 2009
  • 76 Answers
SOURCE: How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Posted on Jul 06, 2010
SOURCE: Sentry Fireproof Safe #1100 Lost Key
no if you turn your lock box around so your key is facing away from you and place your right hand on the side top and your left hand on the box and push the lid to the right a good inch and a half and lift the box will open no problem key or no key. this is a very poorly made safe
Posted on Oct 03, 2010
Bolts on a SentrySafe A3860 are stuck retracted in the door.
Sentry's Customer Service Department is available Monday through Friday, from 8am - 6pm, Eastern Standard time. Our internet Frequently Asked Questions can be accessed on line 24 hours a day, 7 days a week at www.sentrysafe.com
Dec 28, 2013 | Sentry Fireproof Safe
I closed the lock with the dolor open and it will recognize my six digit code
tip from a1 locksmith burlingame you simply have to re enter the lock combination retract the bolts then you should be able to shut the door and lock it.
Oct 03, 2013 | Sentry Fireproof Safe
Can you open a sentry v260 with out a key just the key pad
wont happen you need the key to retract the bolts
Oct 13, 2012 | Sentry Fireproof Safe
I have a sentry 1250. the door is stuck shut. The dialer won't move but the handle will. how can i fix this?
As a locksmith it sounds like the safe is unlocked and the handle is broken. try turning it on it's side and dropping it this might retract the bolts.
Jun 27, 2009 | Sentry Fireproof Safe
I have a sentry SO500. I know the combination but
A locksmith would try to replace the batteries. Sometimes you will get the green light but the batteries still will not have enough power to retract the latch.
Jun 12, 2009 | Sentry Fireproof Safe
Need to reset combination
A good locksmith would tell you all you have to do is line up the notch in the tumbler wheels with the bolt bar. Turn the dial three times to the left and line up the first notch with the bar and note the number. Then turn the dial 2 times to the right to line up the second notch note the number. Then turn the dial left to the last notch note the number and turn the handle to retract the bolts. This will be your sentry safe combination. To dial the safe open see these opening instructions.
May 18, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
122 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
