Question about Nordic Track NordicTrack T5 zi Treadmill
I have had my T5zi for about a year now and all of a sudden the belt stops running.
Treadmill comes on but belt won't run.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have a proform j8 treadmill that makes sudden stops
Look under PROFORM J8 (29798)
Posted on May 14, 2010
  • 1111 Answers
SOURCE: The belt of my treadmill
Hi stewarvm,
you either have a loose belt or possibly a bad bearing.
grab each roller (front and back of treadmill) and try and shake it up and down and front to back to
to make sure the bearings are ok...if they move a lot, then you probably have a bad bearing...if theres no movement, or very litte, they should be ok
now make sure the belts ok by looking at it and determining if one side is looser then the other (the right side should appear or feel looser) then tighten the right adjusting bolt till the belt tracks in the center. the adjuster is at the rear, one on each side of the rear roller.
HERE is a video and instructions of how to track your belt.
its pretty easy to fix and should only take a few minutes to get it right with a little trial an error if you never did it before.
let me know if you need further help.
Bill
Standing Member of G.O.T.
Posted on Nov 15, 2010
SOURCE: nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Posted on Oct 23, 2011
T5Zi treadmill walking belt motor won't start.
Normally when this happen the controller board motor is faulty.
However you must see the schematic diagram , and the thermo switch inside of motor, if is defective or o.k. YOu must use the DMM, for continuity and test if closed or open.Replace or replace.
Of course you must test the main motor, with Battery 12Volts for for to see if the motor is working or defective.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Testing treadmill motor speed control
Nov 19, 2017 | Nordic Track T5ZI Treadmill Drive Motor...
I am either walking or running already for a few minutes and the treadmill part of the treadmill just stops suddenly but computer part still shows all right info. My wife weighs 130lbs. and doesn't have...
If the machine is over 7 years old then you need to replace the walking belt. Most proform treadmills are not meant to be run on, especially by anyone over 220lbs. Forget what the manual says, they are a terrible company.
Sep 07, 2017 | Proform XP Weight Loss 620 Treadmill
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
Treadmill stops running after 10 mins,won't start for about an hour
LUBE the deck belt +rollers bearing. This happen because lack of lube and maintenance according with the s. maintenance
see the video
God bless you
Jan 11, 2013 | Reebok Exercise & Fitness
My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
The belt stopped suddenly and now won't work anymore
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Nov 16, 2009 | NRS Golds Gym Preview 1000 Treadmill
Nordic Track NordicTrack T5 zi Treadmill Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
