Question about iPhone Apps
What is in side mycar key to start it - iPhone Apps
    New Friend:
  • 36 Answers
Usually an encoded transponder.
There is normally an aerial in the steering column, around the ignition key which energises the transponder, allowing the vehicle electronics to verify that the correct key is being used & allowing the electrical, ignition & fuel systems to operate
Posted on May 17, 2014
Testimonial: "how to by pass ?"
Mycar won't start idle air control valve code comes up will that stp car frm starting
Maybe.
The control valve is how the computer controls idle speed.
If the valve is not opening, you should be able to start the engine by pushing down on the gas pedal slightly, or opening the throttle plate in the intake by hand. But it probably won't stay running unless you prop the throttle plate open.
Sep 18, 2015 | Cars & Trucks
I have problem in my jeep grand cherokee when iam start the engine (mycar) is ok started bot when engine start 10 mins after that the engine offline and i dont know the problem please help me!!!
sounds like maybe the immobilizer is activating. try using the key to lock and then unlock the driver's door, resetting the alarm system. the lights should be flashing when this happens but you never know. its a shot in the dark.
Good luck
Feb 28, 2015 | 2004 Jeep Grand Cherokee
When i start mycar the service engine stays on until i start driving
this light comes on when you first start the car but it will go off when you reach a specified speed for your vehicle it is just a reminder
Mar 24, 2014 | 2001 Volvo S60
Bmw 528i starting
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Check ATF at level ground. Top off ATF to MAX level.
Jan 18, 2014 | Cars & Trucks
MYCAR STARTS BUT WANT STAY ON
Look for a light that says SECURITY or ANTITHEFT on your dash when this happens. If you see this light, this explains your symptoms. This link will help that situation.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Dec 23, 2011 | 2003 Pontiac Grand Am
Why is my 2001 pontiac sunfire locked. when i say locked i mean evrything is locked liked the steering wheel,and it would not let me turn the key to crank up mycar. please help
Most commonly, The steering wheel is under tension when it was parked creating pressure on the mechanism that locks everything. Try turning the wheel in aternate directions one at a time while depressing brake and turning key, if this does not work get back to me...MK
Oct 01, 2010 | 2001 Pontiac Sunfire
Mycar wont start ichanged the fuelpump fuse and it keeps blowing its a 2003 pontiac grandam it turns over just wont start
REMOVE FUEL PUMP RELAY.REPLACE FUSE IF STILL BLOWS SHORT IN PCM TO IGNITION CIRCUIT.IF FUSE DONT BLOW I AM LOOKING AT A BAD FUEL PUMP RELAY OR FAULTY FUEL PUMP.
Jul 10, 2010 | 2003 Pontiac Grand Am
Mycar has a vibration problem at 15 45 and 60 mph. even after new tires, alightment and balance.
you may have one of the cv-axle goes bad. jack one side of a time, put parking brakes on.
start the car and put in drive run up to speed and feel the vibration, the side has more vibration is the one that goes bad
Feb 28, 2010 | 2003 Cadillac CTS
Mycar started and died and now will not start or isnt getting spark and u do not hear the fuel pump
SOUND LIKE YOU MIGHT HAVE 2 PROBLEM. 1 NOT GETTING SPARK COULD BE A CRANKSENSOR, 2 FUEL PUMP COULD BE BAD OR CHECK FUEL PUMP FUSE, RELAY. ALSO COULD BE THIEFT SYSTEM CHECK FOR FLASHING THIEFT LIGHT IF FLASHING ITS IN THIEFT MODE.
Nov 03, 2009 | 2006 Kia Rio
Code to car
i think your only choice would be a tow truck to do an unlock of the vehicle.. not sure what they charge. unless of course you have onstar
Jan 06, 2009 | 1995 Ford Explorer
iPhone Apps Logo
54 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
