Question about Whirlpool Gladiator Refrigerator
How di I re-glue the top door gasket? - Whirlpool Gladiator Refrigerator
  • 34 Answers
You may need a cement contact and with the brush roll on frame of the door wait for minute then put the gasket and push it make sure you put it well
Posted on May 17, 2014
3 door maytag refrigerator - bottom door is stuck on one side and will not open.
Accumulation of gunk or even ice on the door gasket can act as a glue between the door gasket and the front edge of the unit. Try using a rag, soaked in hot water and wipe the side of the gasket to try and loosen the gunk or ice.
Apr 18, 2015 | Maytag Refrigerators
The refridgerator door won't seal propertly. We
It could be a bad seal or the door could be sprung without seeing it it is hard to tell. Check the hinges make sure door is properly attached. If it appears to be sprung try pulling on the top of door and pushing on bottom to spring it back into place.... Just not too hard.
Mar 17, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Change out refrigerator door gasket
Hello D Lassiter, You can do this repair yourself with just some basic tools and a little patience and assistance.
You'll need to remove all food from the fridge as it will take at least 45 minutes or longer, depending on how well you do.
If you roll back the door gasket, you'll see the fasteners that hold the gasket in place. Remove these starting with the ones on the bottom edge and then the sides. Finally, remove the top ones, leaving the two top corners for last, that way you can have someone help hold the door liner, so it doesn't drop to the floor and get damaged.
I would also suggest that a day or so before you're going to do the repair, that you let the new gasket lay out on a floor somewhere where it can't get damaged so it will relax and get most of the kinks out of it from shipping, etc.
Then simply put the gasket onto the door liner and reinstall all the screws back onto the door frame.
There are some models (you didn't provide a brand or model number to zero in on the exact version you have) that have the door gaskets glued onto the door frame. On this types, you'll have to use either a plastic or metal putty knive to gently run around the entire edges of the door, between the gasket and the door frame, to get it to come off.
Then you'll need to have someone help you reinstall the new one, as you'll have to reglue the gasket onto the door frame. This will require some non-marring clamps (about 4-6) to hold the inner door panel and gasket onto the outer metal door frame, while the glue dries. Typically, this is done with the fridge door removed from the fridge and takes at least a day once it's installed to glue in it place and fully cure.
In either case, please go to the link below and enter in the model number of your fridge so you can see which type you have and get a line drawing that shows the replacement parts you'll need. You can order them anywhere you wish, it's just very convienent that Sears provides the info for just about all brands of appliances made.
You can find your gasket part at www.searspartsdirect.com by entering in your model number for your unit and looking at the drawings and parts list provided.
You might have to look under the inner door panel edge, hence the reason to look at the middle section or corners to make this a bit easier to do. You might have to remove the inner door panel from the gasket first, in order to get at the screws that hold the gasket onto the metal door frame.
Don't pull on the inner door panel too much, as you really don't want to crack or break it, since your goal is to only remove and replace the gasket. Take your time and you should be able to get it off and replaced.
Of course, don't remove this until you've got the new one available and then allow plenty of time to do the job, which means getting the fridge and freezer emptied completely, so have plenty of coolers available with lots of ice!
I hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Roper Refrigerators
Gasket on freezer split at top running almost aii
you need to strip the door out to fit a new gasket if you can get on that is,, as for the warranty, not a hope! try glue it may be easyer
Nov 19, 2009 | Refrigerators
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to replace door seal on fs1455w
i use a glue called ec 847 or you could try gasket glue and duct tape(put door on top of dryer flat)don't slop glue all over hi hi
Aug 26, 2009 | Washing Machines
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Water is leaking at bottom of door. how do i replace washer
Your local applaince parts store will have the door gasket and the special glue. Sometimes you don't need the glue, but I would get it to be safe. EASY job.
Jun 27, 2009 | Dishwashers
BMW door seal?
make sure you have the new one on hand also the glue you can pick up the glue at a local autoparts store. Now lay the new door seal out in the sun while you are taking the out one off so that its warm and stretches easy, once the old one is off clean the railing that holds the gasket with rubbing alcohol on a rag, then apply the glue as you put on the gasket
May 30, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Whirlpool Gladiator Refrigerator Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
