Hotpoint aqualtis aqxxl129pm
Why does my washer empty s and sometimes it dont ?
    Scholar:
  • 159 Answers
Water pump in the bottom of unit is about to quit all together.might want to get model and serial number go online get factory replacement water pump for that unit. Sorry....
Posted on May 17, 2014
  • 333 Answers
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Posted on Nov 30, 2008
  • 86 Answers
SOURCE: a hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Posted on Jan 02, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
  • 139 Answers
SOURCE: washer will not empty its water -hotpoint washer
Chec to see if the water pump is plugged with lint or some othe debris
Posted on Oct 14, 2009
  • 460 Answers
SOURCE: My Hotpoint Aqualtis washing machine leaves
the drain **** in the machine is partially clogged. my best guess is at the water pump. your washer needs to be serviced. call a serviceman..
Posted on Nov 15, 2009
Aqualtis washing machine has error code F01 what does this mean?
F01 Electronic circuit board fault
Issue: Washing machine is not operating - some or all functions are not selectable.
Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Washing machine blocked how do I unblock?
clean filter at the front or back of the machine will have a turn to the left insert. where the water pipe/s fit take off take top of undo the inlet valve clean out filter. tip up washer find pump you can undo this and clean housing inlets one waste one sump pipe clean and put back clean these hoses thoroughly waste pipe blow through to make sure not blocked that's it.
please rate my answer thankyou
Aug 04, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
How do i unlock the door manually it's locked with the washing inside
do you have the manual I found this answer but have no idea if your machine is like the one described .Then opened the door (if locked use yellow tab behind kicked panel to open
Feb 19, 2015 | Hotpoint Aqualtis AQXXL129PM Washer Front...
?I canot use my washmashine because it doesnt strart ,only are flashes of the lights and nothing else
This model of Aqualtis machine is about 8 years old, I am surprised its lasted as lon, I would suggest the main board has gone, you could try picking one up on EBay for about £35, but i wouldn't waste any more money than that.
Nov 06, 2014 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
