Question about GE WSXH208A Front Load Washer
GE Adora Front Load Washer makes loud noise & smokes on last spin
It is 3 years old. When I wash towels or jeans it makes this horrible sound and starts smoking on the final spin. The tub will be full of smoke when you open the door. Then there are tiny grains of rubber around the door. Small loads and regular loads of light weight clothes aren't a problem so far. Any ideas on what's happening and how to fix it?
4 Suggested Answers
  • 73 Answers
SOURCE: Tub gets easily out of balance when washing towels
there are three or four balancing springs under the drum attached to the frame and drum carriage chances are that one of these springs has broken or come undone they only realy do alot during the spin cycle if you are ambitious turn off the water and unplug the washer pull the back off and have a look see underneath if you do find a broken spring with a pair of pliers bend a new loop in the spring and hook it back up Good Luck
Posted on Oct 13, 2009
Testimonial: "springs are not broken but can they weaken with age.Washer is about 20 years old."
  • 1531 Answers
SOURCE: The washer made a horrible noise and the tub seems
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Posted on Oct 16, 2010
Testimonial: "Sounds like I need to call a repairmen. Thank you so much."
  • 202 Answers
SOURCE: ge adora front load clothes washer washer smoke
new pump
Posted on Mar 22, 2011
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Loud grinding clicking noise during the drain cycle
It sounds like your drain pump has failed or has something stuck in it. You didn't specify a make and model so all I can say is that there are several good videos on YouTube about this problem because it's fairly common. Good luck!
Nov 23, 2013 | Whirlpool LHW0050PQ Front Load Washer
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Noise during spin cycle
what noise is it making, it may just be off balanced
Jan 17, 2012 | GE WSXH208A Front Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I'm so not adoring my adora front loader right now!!!! I know about the cleaning the filter! (Thanks GE!!) My new problem is... when in the wash cycle it is making a HORRIBLE noise. Any suggestions???
try opening the door and lifting the inner drum up, if there is lift in it give it a spin with your hand if it grumbels the main bearings have worn out,, and its not a cheep job to replace them,
Feb 24, 2010 | GE WSXH208A Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE WSXH208A Front Load Washer Logo
267 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
