Question about Maxi-Cosi Baby Gear
Maxi cosi tobi honda jazz - Maxi-Cosi Baby Gear
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
To determine whether the carseat is a suitable fit you should take the vehicle to an authorised Maxi-Cosi retailer and ask for a carseat fitter trained member of staff to provide a physical fitting prior to purchase.
Posted on Aug 17, 2014
  • 419 Answers
SOURCE: Maxi cosi tobi plastic part replacement
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Sep 15, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
SOURCE: straps on my maxi cosi tobi car seat is stuck,
Hi, This sounds like either the harness is twisted at the back or inside, or there is a build up of dirt etc that could have fallen through the **** strap area. I would suggest that you go to this link and contact the supplier who will be able to clarify this for you. http://www.maxi-cosi.com/maxicosi/forms/contact.aspx?mode=contact&language=gb-en I hope this helps.
Posted on Nov 15, 2009
SOURCE: my maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Posted on Apr 23, 2010
  • 286 Answers
SOURCE: the straps on my maxi
hi
you have to pull the buckle towards you if they are still jammed check where the bottom buckle join the seat body to see if there is anything stuck in there if not i would recommend taking it back to the shop and get a replacement,
i had to do this just 4 weeks after buying mine the straps got jammed and i nearly broke little ones arms trying to get him out!
Posted on Oct 18, 2010
Is the maxi cosi combatible with a dodge grand caracvan
Hi Lisa
Please contact Maxi-Cosi customer care team USA & Canada for assistance - 380c2c95-927b-443b-80ce-6a556ec98186.jpg
Feb 09, 2014 | Maxi-Cosi Maxi Cosi Mico Infant Car Seat...
Can you re thread straps on maxi cosi tobi?
Hi
Due to the safety implications of this being incorrectly done it should not be attempted at home. The carseat needs to come in for our engineers to re-thread the harness and ensure it is performing as it should be.
Please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab for your enquiry to go through to the customer care team in your country who can provide further assistance.
Apr 05, 2013 | Maxi-Cosi Tobi Car Seat - Jet Black
I need to clean a child's sickness from the base of my Toby. How do I seperate it?
Hi
It isn't recommended that you take apart the plastic shell of the carseat. You can remove the fabric from the carseat to wash it and then clean the shell with warm soapy water but it is not advisable to remove the harness or to take apart the factory seal of the shell.
Have a look at www.maxi-cosi.com and select the country you're in, then choose the Tobi carseat and select the instructions to view directions on how to remove the fabric.
Sep 24, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to buy new covers and straps for this seat?
Replacement fabrics can be ordered via your local Maxi Cosi retailer or direct from the customer services department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 60GBP and if purchased direct there is 3.99GBP p+p
Jun 25, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to purchase somewhere the white polystyrene inserts on around the headpiece of a maxi cosi toby? Many thanks. R
Good Evening
You can order the replacement polystyrene inserts via most authorised Maxi Cosi retailers or direct with our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm)
Jan 08, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I hope this helps.
Aug 17, 2009 | Maxi-Cosi Baby Gear
Baby Gear Logo
102 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
