Question about Motorola Mobility S305 Bluetooth Headset
Why won't my S305 power on?
Hi, I had been listening to music on my S305, with no low battery warning, powered it off, then could not power it back on. I tried plugging it in, holding down the button, pressed every possible button, nothing. Any suggestions before I toss it?
  • 34 Answers
First of all .. disconnect it from any electric source for 5 minutes and try to power it on propably it won't work did you tried to change the battery .. trie two types if not then there is a problem inside the device it self and you need to send it to the mantianance shop propably some wire or something is disconnected and have been moved from it is place i hope it work
Posted on May 17, 2014
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
My t-mobile g1 keeps randomly turning off and wont turn back on unless i put it to a charger but then when it comes back on the battery life is fine. it only happens when calling people, listening to...
I believe this could be a battery,well we have the same phone and all process you take note sounds like it was my problem before.
Why is this things happening?
Battery can be easily damage due to improper usage like charging the phone while calling,listening to music,browsing etc. two current supply is entering your phone simultaneously. One is coming from the battery powered and the other is coming on the dc charger.the result, it will make your battery deform.
Just replace it a new one and for sure it will be fine again.But please avoid or minimized using your phone while on charge.To be able to preserve your battery life for long time usage.
Hope this simple guide helps you. Thank you for visiting FixYa....
Jul 18, 2011 | HTC G1
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Batter down when Radio switched on
try to soft reset your phone or install anti virus, it sames you are infected with some viruses
use this code to reset *#7780# be sure to back up all your contacts # messages, picture etc before doing this.
After you reset try again reseting in hard reset type *#7370#
default lock code 12345
Jun 20, 2008 | Nokia N70 Cellular Phone
Motorola Mobility S305 Bluetooth Headset Logo
157 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
