Question about KitchenAid KSRD25FK Side by Side Refrigerator
The release button mechanism for the ice storage bin has come apart. How do I put it back together
  • 34 Answers
Check first if there is some clips that can attatch the parts try to put them but slowly in order not to broke it if it is not i suggest to consule someone expert in refrigerator
Posted on May 17, 2014
3 Suggested Answers
  • 1267 Answers
SOURCE: The ice make stopped working. There is ice in the
The icemaker in it's operation hits a microswitch to turn on a warmer in the aluminum tray that aids in extracting the ice by the rotating vanes. It may be that that part of your icemaker has failed.
Try this for a solution first. Remove all of the ice from the bin. Using a hair dryer, melt the ice in the tray and the fill tube. Be sure to warm all of the switches behind the plastic front cap in case those switches are frozen. Let the ice maker fill again and see if you have made ice. Often splashed water will freeze the rotating vanes and will not let the ice maker rotate through it's complete cycle.
Posted on Mar 08, 2011
spyder301975
  • 99 Answers
SOURCE: Can't remove ice storage bin from Kitchenaid side by side
This units are prone to do this. Best way for me to tell you is to work ice bucket side to side. Then shut the freezer door and switch between the cube and crushed ice. Tap the dispenser lever just long enough to engage motor. Basically you are rocking the coupling back and fourth in the auger assembly. Will come loose but may take a bit.
Posted on Aug 18, 2012
HOW TO REMOVE ICE MAKER STORAGE BIN ASSEMBLY IN FREEZER
empty freezer put a pot of boiling water under the ice bin and let it melt it
May 10, 2016 | Refrigerators
Kenmore coldspot model 10657282791 ice maker dispenser crusher frozen
When you say "frozen" do ya mean that all the ice in the storage bin is one huge block of ice??
if yes all the ice is frozen together,that is caused by a malfunctioning water inlet valve that is not fully closing yet stays opena wee bit allowing water to seep into the storage bin and freezing all the ice together. To repair that the water inlet valve would need to be replaced. Its part number 2188542 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Refrigerators
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
The ice and/or water won't stop coming out the door when the back soft panel area is pressed. Either ice or water keep coming out when the back is pressed with a glass until door is opened. When the door...
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Sep 28, 2010 | LG LRSC-26922 Side by Side Refrigerator
The part where you would press to get ice, well up in side is not releasing the ice and closing back
On mine, using crushed ice will cuase a build up of ice along the shoot. I take off the storage bin and manually open the door cleanining out the shoot. Make sure to check under the removed storage bin before replacing.
Aug 30, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
KitchenAid KSRD25FK Side by Side Refrigerator Logo
47 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
