Question about Home Security
How to close an SW3750 safe (by Sentry Safe)
I bought a home with a SW3750 Safe. I was able to open it with a key and a code but I cannot close it now. What do I need to do?
  • Bernardo Gomez May 17, 2014
    By closing I mean the spindles or metal locking bars are not poping out nor can I get the handle back to the horizontal position
  • Bernardo Gomez May 19, 2014
    Hinges are not obstructed and door closes all the way. Still won't close. Thanks
    Scholar:
  • 159 Answers
Look in locking holes for obstructions .check to see if hinges are obstructed and the door will not lock unless it closes all the way.
Posted on May 17, 2014
  • 2,013 Answers
To close and lock
You can relock the safe in two ways. With the door
closed, depress the key lock (if equipped) with your
finger, or spin the combination dial one full turn.
For greatest security, do both. (Make sure the door
handle is in the horizontal position.) There is a link to the manual at the bottom of this page...
http://www.sentrysafe.com/Products/380/SW3750_Electronic_FIRE-SAFE_
  • 80 Answers
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
the instructions are located link above.
mj
Posted on Sep 07, 2009
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: need to reprogram my sentry v360 safe. forgot my code
for instructions use link above.
mj
SOURCE: Sentry Fireproof Safe #1100 Lost Key
no if you turn your lock box around so your key is facing away from you and place your right hand on the side top and your left hand on the box and push the lid to the right a good inch and a half and lift the box will open no problem key or no key. this is a very poorly made safe
Posted on Oct 03, 2010
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Bought used sentry fire safe model sw3750 , key works, replaced batteries but do not know electronic code
Brian, You can contact the manufacturer at link below, you will need factory code from them to reset. They will need forms filled out before supplying info.
http://www.sentrysafe.com/Products/57/A3750_FIRE-SAFE_HomeOffice_Safe
Apr 08, 2016 | Home Security
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
Open sentry safe key
contact sentry safes customer support or your local locksmith
if in Fort Lauderdale area try
Mar 23, 2014 | Sentry Safe SentrySafe Safe. Fire Safe 1.2...
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Mar 22, 2009 | Sentry Fireproof Safe
Sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Oct 19, 2008 | Sentry Fireproof Safe
Sentry safe msw3517
Mar 16, 2008 | Sentry Fireproof Safe
Home Security Logo
191 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
