Question about Electrical Supplies
Why gmc truck c4500 brake lights not working - Electrical Supplies
    Genius:
  • 1,056 Answers
#1) Have you checked the fuse for the brake lights? Check it, if bad, replace, if not
#2) Have you checked the bulbs? Not knowing what year truck you have kind of changes this part, it the brake and turn signal bulbs are the same bulb, do the turn signals light up? If no, the bulbs are bad, replace the bulbs; if yes, go back to step #1 and double check the fuse.
#3) there is a contact switch at your brake peddle; you can try jumping the 2 terminals to see it the brake lights will work; if they do, it's a bad brake light switch, replace it, there is no rebuilding them. If they don't work after jumping the switch, it's a problem with power to the switch, back to #1 check the fuse.
Posted on May 17, 2014
My C4500 2005 will not go into overdrive
Things to check: Transmission control module, torque converter, OD shift solenoid on the valve body of the transmission.
Aug 22, 2016 | BD Diesel 2001-2005 Chevrolet/GMC Duramax...
How to repair not working rear lights 1997 gmc jimmy
brake lights not working - 1997 GMC Jimmy - RepairPal
repairpal.com > Questions > GMC > Jimmy > 1997 GMC Jimmy
Jan 11, 2011 - hi about 2 days ago i realized my brake lights were not working but my turn signal lights were working and parking lights as well but no brake ...
Tail Lights don't work but third brake light does, not fuses ...
answers.edmunds.com > Edmunds Answers
Sep 23, 2009 - 97 GMC Jimmy 4x4 blinkers work, reverse lights work, above window ... I just lost hazard lights and rear brake lights, they were working 2 days ... If it is a frayed wire or solder point, then you can repair it, but not any worn contacts. ... Does anyone have any suggestions on 1997 Honda Accord tail & brake lig.
Nov 19, 2015 | GMC Cars & Trucks
I just installed led tail lights in my 2003 gmc sierra everything works but the brake lights any ideas?
First, verify that the brake lights work correctly with the old lights. If your blinkers work, the brake lights should work as well.
It is possible that your brake lights were not working previously. If they do not work, suspect a blown fuse or a defective brake light switch.
May 11, 2015 | 2003 GMC Sierra
Brake lights not working on 96 gmc jimmy
check fuse
if fuse is good check brake pedal switch
check grounds
Jun 03, 2010 | 1996 GMC Jimmy
2002 GMC sierra brake lights not working. Reverse and blinkers ARE working!
Check fuses first. If thats OK, could be a problem with the brake switch (down by the pedal) or the wiring.
Mar 26, 2010 | 2002 GMC Sierra
Brake lights wont work right tail light wont work 2003 gmc envoy
check globes and check brake light switch under dash on brake pedal.
Oct 27, 2009 | 2004 GMC Envoy
1999 GMC Suburban, K1500 4WD. Top brake light bar
third light is different circuit. saftey reason check fuses grounds wires
Oct 10, 2009 | 1999 GMC Suburban
No brake lights, or no signal lights
brake lights and turn signals work off the same curcit, it could be the fuse or the brake light switch !!!!!!
Jun 05, 2009 | 2000 GMC Sierra
Brake lights don't work. Fuse is good, bulb is good, but brakes still won't come on. GMC Sonoma 1994.
please check your brake light switch located near the brake pedal. it could be faulty.
tnx 4 using fixya,
drcool
Sep 24, 2008 | 1999 GMC Yukon
Electrical Supplies Logo
115 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
