Question about managemylife.com
Why is water not dripping out of the ac when there is 1/4 inch fall
    Top Expert:
  • 3,698 Answers
Either the drain hole is plugged or the fall is too much and water is passing up the slightly raised drain hole.
Posted on May 17, 2014
When ac is on water drips onto passenger floorboard of 2010 hyundai elantra touring with 64000 miles. Drip line under car still drains water
Sounds like the drain hose is clogged up. Open hood and on the firewall on the bottom look for a rubber hose about an inch or two long sticking out of the firewall blow a short burts of air into it and the debris should come out
Aug 15, 2013 | Cars & Trucks
Ac drip line
At the point of drip there should be a small tube . not very long and about 1/2 inch in dia. attach a garden hose to it and lay the hose out keeping a downward slope all the way to where you want it to run. Failing that use electrical conduit (plastic) and various bends to get the water to where you want it to go
May 26, 2013 | Heating & Cooling
Goodman AC drip pan full and the filter is wet
so you used a hose to blow it out but nothing came out? if so the problem is in the piping. you must have 1/4 inch per foot of fall with no sags unless you are using a condensate pump
Sep 03, 2012 | Goodman Heating & Cooling
Water drips into the camper through the foam rubber air intake, after it runs for awhille
Sounds like your drains for drip pan under the evaporator area are plugged. They are located at the base of the AC unit on roof. Look real close under AC unit near front, for a hole in base plate of AC on each side. Water ( condensation ) should be dripping out of those holes pretty steady when running.
You should have an inch or so clearance between base of AC and roof to try and get a bent piece of wire, or similar in to hole and try to clean it out. If that doesn't help you will have to remove plastic cover and remove all the screws that hold the front cover over the evaporator and remove the front metal cover. Look down at base of the coils and fins and you will see a drip pan that has small holes at each end for drainage. They will get plugged up with debris, thus poor, if any drainage. I use a long air nozzle and a small compressor to blow them and the tray out to clean it well. That will usually cure your problem. Please remember to shut all power to AC, off at breaker panel before removing the cover on roof to avoid electrical shock.
Sep 04, 2011 | Dometic 57915531 Air Conditioner
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
This is a 52 inch HI DEF Projection TV 4 years old and the picture went out when water dripped on the back panel. What could be wrong?
Depending on where the water dripped in the chassis. It could have blown a fuse at the AC source if it will not power up at all. Be sure it is completely dry before trying another fuse
May 19, 2011 | Hitachi Televison & Video
WATER COMING OUT OF HEAD UNIT when air con. on
May be normal. Mostly likely this is condensation that spits out of the head units of most AC units.
Mar 08, 2011 | Heating & Cooling
Water leaking on passenger side possibly from air conditioning
THE AC EVAPORATOR CORE WATER CONDENSAION DRAIN IS PLUGGED, THE DRAIN IS AT THE BASE OF THE ENGINE FIREWALL ON THE PASSENGER SIDE OF ENGINE COMPARTMENT, U WILL NEED TO GET UNDER THE VAN TO SEE IT, WILL BE ABOUT 1/2 INCH DIAMETER TUBE.
Jul 03, 2009 | 2003 Chrysler Town & Country
Frigidaire thru-wall AC drips water when AC is on
The drain line is clogged.You will have to remove it again,open it up and access the drain line and clean it out.
It will be on the right or left corner of the evaporator coil(inside coil).
You will probably have to take it outside and use a garden hose the spray water into the drain until it runs freely.
When you reinstall it tilt it 1/2 inch to the rear.
May 25, 2009 | Frigidaire FAC124 wall/Window Air...
Espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Apr 17, 2009 | Coffee Makers & Espresso Machines
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
