How do I know if the flex cable or the LCD screen is broke on my acer aspire one notebook?
When I turn on the laptop the screen is white, doesn't show any cracks or breaks and you can not hear anything.
Remove betree on your laptop and then turn on your laptop while you connect to the source of power or turn on your laptop without connect to the source of power
Posted on May 17, 2014
patemi
  • 366 Answers
SOURCE: how to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Posted on Jan 08, 2009
imp_squared
  • 56 Answers
SOURCE: Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Posted on Oct 01, 2008
  • 217 Answers
SOURCE: flex cable(flat type)
The cable isn't nearly as fragile as the LCD screen. It sounds like the screen is broken. The flex cable is alot cheaper to replace, so you can always try that first.
Posted on Jan 31, 2008
bharrie
  • 158 Answers
SOURCE: Screen on laptop goes white
Maybe cuz of screensaver. disable the screensaver.
Posted on Jan 15, 2009
Murphybanton
  • 2004 Answers
SOURCE: Unable to remove screen surround on Acer Aspire 6930
Walk into a Computer hardware shop. Of course they will have all the required tool to open the laptop up and fix the new screen.
Posted on Mar 17, 2009
Hi there my acer aspire 4315 laptop turns all white when i turn on my laptop?? i dont know why this does this??? but i have sent it to a expert but they didnt fix it at all. i often fold the screen down...
At least you know the back-light works. There is a ribbon cable that connects the video to the LCD screen from the lower part of the laptop - sometimes it wears out because it is not properly seated, then it breaks. Try connecting an external monitor to the VGA port and see if you get the same symptom. If it works ok, then that ribbon cable is broke.
Nov 12, 2010 | Acer Aspire 4315 Notebook
Acer aspire 5735 will start up however there is no picture on screen
Try to connect your laptop to a external monitor/lcd screen if it will display this will prove that the problem might be on the flex cable from your lcd to the board or might be an inverter problem.
Jul 24, 2010 | Acer Aspire 5735 Notebook
My laptop monitor turns white screen whenever I open it. What might be the problem?
The white screen occurs because of the loose contact of the lcd cable with the motherboard.Open the laptop and fix the cables tightly.It will work fine.
Mar 18, 2010 | Acer Aspire One PC Notebook
My acer aspire 4520 laptop makes it to the acer screen when i turn it on but the screen is dark almost black. thats as far as it gets before the screen goes black. if you press the power button it turns...
Hello scooby_chick
First off, nice nickname you got there.:)
Anyway, there's a chance that the flex, the cable that connects your screen & the laptop itself may be defective.
I had a similar thing happen to my pre-historic Sharp laptop.
Try calling Acer or where you bought that laptop to see how you can go about in replacing the flex cables.
Hope that helps & best of luck!
Art Pena
Tech Support
Nov 23, 2009 | Acer Aspire One PC Notebook
1/4 of Acer 5735 Screen is not working properly
Jo
You can try reseating the LCD cable but the issue is most likely a LCD failure (Replacement of the LCD required)
Oct 09, 2009 | Acer Aspire 5735 Notebook
Acer aspire 5570z white screen
its either going to be a problem with the lcd, inverter or output from the motherboard probably.
Best thing to do is to try a different lcd with a different lcd cable, then if that doesn't work, then try to get a different inverter, if that doesn't work then you'll know for sure its the output coming from the motherboard.
Alot of times the LCD's go bad but the lcd cables go bad cause they are flimsy and the wires break inside.
Look on Ebay cause you can easily get these parts cheaper then most places.
Aug 09, 2009 | Acer Aspire 5535-5050 Notebook
I hav problem with my acer aspire 4710. it screen turns white.
ACER PICTURE PROBLEM – MY SOLUTION
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
http://www.insidemylaptop.com/category/1-acer-laptops/
Hope this helps. (Please rate my advice)
Jan 30, 2009 | Acer Aspire 3610 Notebook
White screen problem while starting Acer Notebook 4710
i think this is ur lcd problem ,u need to replace lcd
Jan 20, 2009 | Acer Aspire 3680 Laptop
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
My acer aspire4310 notebook suddenly displays a white screen
If you have blue strip running down vertically from top to bottom then normally there is a problem with LCD or a loose LCD cable.But what I recommend you to test more is tha,t if you tab at the back of your screen ...does this problem occur ???
Incase it does,then its a loose LCD cable problem.You still need
a qualified person who knows how to open the monitor to repair inside.
And again for the White screen it can also be both cases I mentioned above
ByeBye,takecarfe
Apr 22, 2008 | Acer Aspire 5610-4648 Notebook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
