Question about Royal wes50 surround sound wireless headphones
Can you buy replacement batteries for the head phones?
    Top Expert:
  • Royal Master
  • 3,698 Answers
Https://www.royalsupplies.com
Try going to their website and ask them.
Posted on May 17, 2014
Where can I purchase replacement batteries at a reasonable cost? Model BT-1007
Reasonable price depends on the person buying something. When I have purchased replacement batteries for a cordless phone I have gone to Radio Shack or Best Buy. Now depending on the age of the phone, you might be better off buying a new phone rather then replacing the battery, because some of the batteries can run almost as much as a new phone.
May 01, 2014 | Uniden Cordless Phone
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Can batteries be replaced on Motorola boost mobile cellular phone 1415
I suggest you Google the Internet for a battery for your model cell phone. You will get various suppliers and prices then you can decide whether to buy a new battery or a new smart phone.
Mar 13, 2013 | Motorola Mobility Boost i415 Cellular...
No sound in ear phones.
Well if you really dont want to buy new head phones , go to best buy. Or look up on google who fixes earphones and where they fix them at. But i highly suggest you to get a new pair of ear phones.
Jan 23, 2013 | Sennheiser RS 110 Consumer Headphones
Battry low 2hours
The problem is either the battery is weak or the phones terminal head consumes battery.
To solve the battery problem, all you have to do is to replace the battery with a new one, to confirm if it is the battery, first try to use the battery when fully charged in another phone, to see if it works lesser than 2 hours or above 2 hours. If it works for 2 hours then it is the battery, and if it lasts beyond 2hours then it means the battery is okay.
For the battery terminal head, you will have to open the phone up with the appropriate screwdriver, then you get a soldering iron to melt off the lead on the terminal head, then you replace it with a new one. The terminal head is the metallic object that connects the battery to the phone, that helps the phone receive power from the battery.
After checking and solving the problem, your phone should be in good shape.
Take care and good luck
NB: if you are not familiar with such technical activities, i will strongly advice you seek technical assistance from a professional close to you in order for you not to damage any part on the panel, as erevy part inside the phone are very fragile and require very careful and thorough process.
Oct 19, 2010 | Samsung SGH-J600 Cellular Phone
I have a Motorola V3m, battery is well but dischaging vey fast, when charge my cell phone it's very hot back.
The symptoms makes it so clear that the problem is from the terminal head of the phone.
The terminal head is the thin iron sheets that makes contact with the battery.
To fix this, you have to open up the phone, to fix this, follow the process below;
  1. Get the appropriate screwdriver,
  2. Remove the battery cover, battery and sim,
  3. Then you unscrew the compartment behind the phone.
  4. Run an object like a credit card along the tip of the phone to split the phone in two.
  5. Yo will have access to the Terminal head, remove it and replace it with a new one,
  6. Reverse the process to reassemble the phone back together.
Take care
Jun 26, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
The battery runs out of charge quickly
The reason your battery runs out of charge might be because the battery is faulty or the phones terminal is consuming the battery.
If the phone gets hot at the back when it works for some time, then it is terminal.
To test if it is the battery, try to use the battery in another phone to see how long it lasts.
If it works fine, then it is the terminal head, but if it does not, then it is the battery, and if it is the battery, all you have to do is replace it.
The terminal head is the metals at the back of the phone that connects the battery to the phone.
To fix this, get a similar terminal head, get the appropraite screwdriver, open the phone.
Carefully disconnect the terminal head and and replace it with a new one.
Then couple back the phone, charge the battery for a while and turn on the phone.
Use it for a while to test if it is ok.
Take care.
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I haveolder radio shack 900mhz stereo head phones. it says it uses nimh 3.6volt 280mAh battery pack. I cannot find a replacement any where. Any help would be greatly appreciated.
Most of the battery can be build and replace. Look at specialist like onlybatteries.com where you can buy any kind of battery cells, with tabs if need that you can weld, or make weld at your local electronic shop repair. Keeps the old pack, open it with a xacto without breaking it or a dremel and check how its made. its usually AA nimh battery...
Oct 07, 2009 | RCA WHP141 Consumer Headphones
Royal wes50 surround sound wireless headphones Logo
66 people viewed this question
Top Royal Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Royal Audio Player and Recorder Expert? Answer questions, earn points and help others
